Re: [mpich-discuss] MPI_Send/MPI_Recv - getting delayed indeffinitely
Are you suggesting using non-blocking send/recv? Sent from my Windows phone -----Original Message----- From: "Pavan Balaji" <[email protected]> Sent: 12/26/2013 12:29 To: "[email protected]" <[email protected]> Subject: Re: [mpich-discuss] MPI_Send/MPI_Recv - getting delayed indeffinitely On Dec 25, 2013, at 8:50 PM, Madhawa Bandara <[email protected]> wrote:
Thanks for the response. Actually I was using float as the data type in the program whereas MPI_DOUBLE is used in communication.. That has been the reason
Ok, great.
Serializing means assigning a tag?
Not exactly. Serializing is probably not the correct terminology here. The problem is what I described in my response. worker2 might send the message before worker1, in which case, it will have to wait for the master to receive worker1’s message and then process its message. If it’s not causing performance degradation for you, don’t worry about it. — Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Madhawa Bandara
