Re: [mpich-discuss] mpiexec.hydra binding for multiple compute nodes
Oh okay. I see that one of the binding options within hydra is to bind to the motherboard. Would that allow one to assign ranks to certain nodes? (Assuming that my compute node only has one motherboard). If I had #SBATCH -N 2 and #SBATCH -n 32 y guess is to have something like '-bind-to board' sequentially bind 0-15 to node 0 and 16-31 to node 1, or would this option still result in striped even/odd assignments? But yes otherwise I would very much like to be included in that CC if a ticket is to be made. Thanks On Wednesday, May 13, 2015, Kenneth Raffenetti <[email protected]> wrote:
Ah, you are right. They will be striped odd/even across the nodes. Not sequentially. I don't see a way to serve that binding with the current options. It's something we can look at adding in a future release. I'll open up a ticket and add you to the CC list, if you are interested.
Ken
On 05/12/2015 02:16 PM, Justin Chang wrote:
So just to be clear, if I have the following script:
#SBATCH -N 2 #SBATCH -n 32
mpiexec.hydra -bind-to user:0,1,2,3,4,5,6,7,10,11,12,13,14,15,16,17 -n 32 ./my_program <args>
ranks 0-15 will be binded as such on the first node and ranks 16-31 will be the same for the second node? Or will all the even ranks be on one node and the odd on the other?
On Mon, May 11, 2015 at 9:27 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
Ah, I see now the problem. I misread the first email. Your original line should work fine! The user bindings are listings of hw elements, not processes, so your binding will be applied identically on each node.
Ken
On 05/11/2015 05:03 PM, Justin Chang wrote:
Ken,
"-bind-to core" gives me the following topology:
process 0 binding: 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 1 binding: 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 2 binding: 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 3 binding: 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 4 binding: 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 5 binding: 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 6 binding: 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 process 7 binding: 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 process 8 binding: 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 process 9 binding: 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 process 10 binding: 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 process 11 binding: 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 process 12 binding: 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 process 13 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 process 14 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 process 15 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0
but I want this:
process 0 binding: 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 1 binding: 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 2 binding: 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 3 binding: 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 4 binding: 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 5 binding: 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 process 6 binding: 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 process 7 binding: 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 process 8 binding: 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 process 9 binding: 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 process 10 binding: 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 process 11 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 process 12 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 process 13 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 process 14 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 process 15 binding: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0
The latter gives me better performance for my application, and I am guessing it's because I have evenly distribute the processes among the two sockets (sequentially). Which is why I resorted to what I had originally with the custom binding.
On Mon, May 11, 2015 at 4:53 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Justin,
Try using the "-bind-to core" option instead. It should do exactly what you are wanting. See this page with examples for more details
https://wiki.mpich.org/mpich/index.php/Using_the_Hydra_Process_Manager#Proce...
Ken
On 05/11/2015 04:48 PM, Justin Chang wrote:
Hello everyone,
I am working with an HPC machine that has this configuring for a single compute node:
Machine (64GB total) NUMANode L#0 (P#0 32GB) Socket L#0 + L3 L#0 (25MB) L2 L#0 (256KB) + L1d L#0 (32KB) + L1i L#0 (32KB) + Core L#0 + PU L#0 (P#0) L2 L#1 (256KB) + L1d L#1 (32KB) + L1i L#1 (32KB) + Core L#1 + PU L#1 (P#1) L2 L#2 (256KB) + L1d L#2 (32KB) + L1i L#2 (32KB) + Core L#2 + PU L#2 (P#2) L2 L#3 (256KB) + L1d L#3 (32KB) + L1i L#3 (32KB) + Core L#3 + PU L#3 (P#3) L2 L#4 (256KB) + L1d L#4 (32KB) + L1i L#4 (32KB) + Core L#4 + PU L#4 (P#4) L2 L#5 (256KB) + L1d L#5 (32KB) + L1i L#5 (32KB) + Core L#5 + PU L#5 (P#5) L2 L#6 (256KB) + L1d L#6 (32KB) + L1i L#6 (32KB) + Core L#6 + PU L#6 (P#6) L2 L#7 (256KB) + L1d L#7 (32KB) + L1i L#7 (32KB) + Core L#7 + PU L#7 (P#7) L2 L#8 (256KB) + L1d L#8 (32KB) + L1i L#8 (32KB) + Core L#8 + PU L#8 (P#8) L2 L#9 (256KB) + L1d L#9 (32KB) + L1i L#9 (32KB) + Core L#9 + PU L#9 (P#9) HostBridge L#0 PCIBridge PCI 1000:0087 Block L#0 "sda" PCIBridge PCI 15b3:1003 Net L#1 "eth0" Net L#2 "ib0" OpenFabrics L#3 "mlx4_0" PCIBridge PCI 8086:1521 Net L#4 "eth1" PCI 8086:1521 Net L#5 "eth2" PCIBridge PCI 102b:0533 PCI 8086:1d02 NUMANode L#1 (P#1 32GB) + Socket L#1 + L3 L#1 (25MB) L2 L#10 (256KB) + L1d L#10 (32KB) + L1i L#10 (32KB) + Core L#10 + PU L#10 (P#10) L2 L#11 (256KB) + L1d L#11 (32KB) + L1i L#11 (32KB) + Core L#11 + PU L#11 (P#11) L2 L#12 (256KB) + L1d L#12 (32KB) + L1i L#12 (32KB) + Core L#12 + PU L#12 (P#12) L2 L#13 (256KB) + L1d L#13 (32KB) + L1i L#13 (32KB) + Core L#13 + PU L#13 (P#13) L2 L#14 (256KB) + L1d L#14 (32KB) + L1i L#14 (32KB) + Core L#14 + PU L#14 (P#14) L2 L#15 (256KB) + L1d L#15 (32KB) + L1i L#15 (32KB) + Core L#15 + PU L#15 (P#15) L2 L#16 (256KB) + L1d L#16 (32KB) + L1i L#16 (32KB) + Core L#16 + PU L#16 (P#16) L2 L#17 (256KB) + L1d L#17 (32KB) + L1i L#17 (32KB) + Core L#17 + PU L#17 (P#17) L2 L#18 (256KB) + L1d L#18 (32KB) + L1i L#18 (32KB) + Core L#18 + PU L#18 (P#18) L2 L#19 (256KB) + L1d L#19 (32KB) + L1i L#19 (32KB) + Core L#19 + PU L#19 (P#19)
If I ran my program with 16 processes, I would have the follow batch script:
#!/bin/bash #SBATCH -N 1 #SBATCH -n 20 #SBATCH -t 0-09:00 #SBATCH -o output.txt
mpiexec.hydra -bind-to user:0,1,2,3,4,5,6,7,10,11,12,13,14,15,16,17 -n 16 ./my_program <args>
This would give me decent speedup. However, what if I want to use 32 processes? Since each node only has 20 cores I would need #SBATCH -N 2 and #SBATCH -n 40. However, I want ranks 0-15 and 16-31 to have the same mapping as above but on different compute nodes, so how would I do this? Or would the above line work so long as I have a multiple of 16 processes?
-- Justin Chang PhD Candidate, Civil Engineering - Computational Sciences University of Houston, Department of Civil and Environmental Engineering Houston, TX 77004 (512) 963-3262 <tel:%28512%29%20963-3262> <tel:%28512%29%20963-3262>
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Justin Chang
