Re: [mpich-discuss] credentials for mpiexec -f machinefile
That does the trick. I set: export MPIR_CVAR_CH3_PORT_RANGE=10100:10200 set up all the firewalls, and waited for mpiexec to time out. This way I can see which port it decided to open. Now I see port 10100 is being used. [cosy11@oswrk210 mpich-3.1]$ mpiexec -f machinefile2 -n 4 ./examples/cpi [proxy:0:[email protected]] HYDU_sock_connect (utils/sock/sock.c:172): unable to connect from "oswrk207.lns.mit.edu" to "198.125.163.210" (Connection timed out) [proxy:0:[email protected]] main (pm/pmiserv/pmip.c:189): unable to connect to server 198.125.163.210 at port 10100 (check for firewalls!) Next, I open only a range of ports on the openStack controller: and my pi computation went through: [cosy11@oswrk210 mpich-3.1]$ mpiexec -f machinefile2 -n 4 ./examples/cpi Process 3 of 4 is on oswrk207.lns.mit.edu Process 2 of 4 is on oswrk207.lns.mit.edu ProcessB 0 of 4 is on oswrk210.lns.mit.edu ProcessB 1 of 4 is on oswrk210.lns.mit.edu pi is approximately 3.1415926535902168, Error is 0.0000000000004237 wall clock time = 0.161488 Thanks a lot - this lets me move forward. You can close this ticket Jan On Apr 23, 2014, at 11:35 PM, "Balaji, Pavan" <[email protected]> wrote:
Jan,
It looks like mpiexec is not respecting all the aliases for that environment variable. Can you use MPIR_CVAR_CH3_PORT_RANGE to set the port range for now? We’ll add MPICH_PORT_RANGE as an alias for it in the next release.
FWIW, use the README.envvar for the environment variable names. They should contain the correct information. Aliases are only maintained for backward compatibility.
— Pavan
On Apr 23, 2014, at 10:06 PM, Jan Balewski <[email protected]> wrote:
On Apr 23, 2014, at 5:32 PM, Kenneth Raffenetti <[email protected]> wrote:
You can control the port range that mpich will use. See this item in the FAQ
http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_How_do_I...
Hi, Thanks, but somehow setting of MPICH_PORT_RANGE variable on the master VM does not propagate. mpiexec still tries to open the port 34781 which is out of the range set by export MPICH_PORT_RANGE=10000:10100
I'm missing sth - not sure what? Jan
-------- [cosy11@oswrk210 mpich-3.1]$ echo $MPICH_PORT_RANGE 10000:10100
[cosy11@oswrk210 mpich-3.1]$ mpiexec -f machinefile2 -n 4 ./examples/cpi [proxy:0:[email protected]] HYDU_sock_connect (utils/sock/sock.c:172): unable to connect from "oswrk207.lns.mit.edu" to "198.125.163.210" (Connection timed out) [proxy:0:[email protected]] main (pm/pmiserv/pmip.c:189): unable to connect to server 198.125.163.210 at port 34781 (check for firewalls!)
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jan Balewski
