tried to cd and do this command but premission denied so i did sudo and then he said mpicc: command not found. cluster@elec-cluster-1 ~/mpich2/mpich-3.1/examples $* mpicc -o cpi cpi.c* /usr/bin/ld: cannot open output file cpi: Permission denied collect2: ld returned 1 exit status cluster@elec-cluster-1 ~/mpich2/mpich-3.1/examples $ *sudo mpicc -o cpi cpi.c* [sudo] password for cluster: sudo: mpicc: command not found 2016-03-23 18:09 GMT+02:00 sanjesh pant <[email protected]>:
First compile it by using command as mpicc -o cpi cpi.c On 23 Mar 2016 21:33, "יוסף אלון" <[email protected]> wrote:
but i do want to run a C source code all over the nodes? and allso when i run only the cpi witout .c nothing is hapning. i think you the only one who can help me. thank you
2016-03-23 17:59 GMT+02:00 Kenneth Raffenetti <[email protected]>:
The executable MPICH builds (and you want to run) is "cpi" in the examples. cpi.c is a C source code file and is not executable. I suggest you read more on how to build and execute C programs if you still have questions.
Ken
On 03/23/2016 10:43 AM, יוסף אלון wrote:
what do you mean?
2016-03-23 17:42 GMT+02:00 Kenneth Raffenetti <[email protected] <mailto:[email protected]>>:
cpi.c is a source file, not an executable.
On 03/23/2016 10:41 AM, יוסף אלון wrote:
when i do this i reciev:
cluster@elec-cluster-1 ~ $ *_mpiexec -n 5 -f machinefile ./mpich2/mpich-3.1/examples/cpi.c_* [proxy:0:0@elec-cluster-1] HYDU_create_process
(/home/cluster/mpich2/mpich-3.1/src/pm/hydra/utils/launch/launch.c:75): execvp error on file ./mpich2/mpich-3.1/examples/cpi.c (Permission denied)
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 2895 RUNNING AT 147.161.4.200 = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=================================================================================== [proxy:0:1@elec-cluster-2] HYDU_create_process
(/home/cluster/mpich2/mpich-3.1/src/pm/hydra/utils/launch/launch.c:75): execvp error on file ./mpich2/mpich-3.1/examples/cpi.c (Permission denied) [proxy:0:4@elec-cluster-5] HYDU_create_process
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 7382 RUNNING AT 147.161.4.201 = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
2016-03-23 17:34 GMT+02:00 Kenneth Raffenetti <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>>:
The error in your first message was that mpiexec was unable to find the file "./examples/cpi".
The error in your second message is that mpiexec was unable to find your "machinefile".
Please make sure you are giving the correct paths to these files in your mpiexec command.
Ken
On 03/23/2016 10:20 AM, יוסף אלון wrote:
i am not using a share network and i have it on the place in all nodes. and thus file are located in same place on every node. i tried to run like this allso תמונה מוטבעת 1
2016-03-23 17:06 GMT+02:00 Kenneth Raffenetti <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> <mailto:[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>>>:
Are you executing your commands from a shared network filesystem? If not, have you copied your MPI installation and cpi binaries into the same location on all the machines in your cluster?
Ken
On 03/23/2016 09:47 AM, יוסף אלון wrote:
hiii
i am new here and i have a 18 node cluster that works pretty good when i execute the command:
*mpiexec -f machinefile -n 18 hostname * and the folowing output: elec-cluster-1 elec-cluster-2 elec-cluster-3 elec-cluster-5 elec-cluster-4 elec-cluster-6 elec-cluster-7 elec-cluster-9 elec-cluster-8 elec-cluster-10 elec-cluster-11 elec-cluster-13 elec-cluster-14 elec-cluster-15 elec-cluster-16 elec-cluster-12 elec-cluster-18 elec-cluster-17
when i execute the command: *mpiexec -n 5 -f machinefile ./examples/cpi*
nothing is seems to work and i receive:
(/home/cluster/mpich2/mpich-3.1/src/pm/hydra/utils/launch/launch.c:75): execvp error on file ./examples/cpi (No such file or directory)
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 2806 RUNNING AT 147.161.4.200 = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=================================================================================== [proxy:0:2@elec-cluster-3] HYDU_create_process
(/home/cluster/mpich2/mpich-3.1/src/pm/hydra/utils/launch/launch.c:75): execvp error on file ./examples/cpi (No such file or directory) [proxy:0:3@elec-cluster-4] HYDU_create_process
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 6718 RUNNING AT 147.161.4.202 = EXIT CODE: 255 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
i dont know what to do? another think is how to run and compile a c program?
-- בברכה, יוסף אלון 050-4916740
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> <mailto:[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto: [email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- בברכה, יוסף אלון 050-4916740 _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
יוסף אלון
