Re: [mpich-discuss] Mac OS X version of Mpich
See below where you got a warning for defining MPI to 1? That is going to break EVERYTHING in the MPI C code. Consider the declaration MPI_Init_thread. It will become 1_Init_thread. This is a serious problem. The MPI standard reserves the MPI namespace. You cannot use it. In your case, you took the entire namespace and changed it to a number :-) Please use a preprocessor macro like USE_MPI in your application. Do not define any symbols anywhere that being with MPI. Related: http://lists.mpich.org/pipermail/devel/2013-November/000274.html. It's the number 1 google hit for me and the first response is the correct answer. Best, Jeff On Tue, Aug 18, 2015 at 11:39 PM, Benjamin Svetitsky <[email protected]> wrote:
Greetings MPICH experts,
I've run code with MPICH often on my Macbook Pro (4 cores), but not lately. Recently I updated MPICH from Macports, preparing for new running. Now my code doesn't compile. Do you know this error message: ------ mpicc -c -O3 -DMPI -DPRECISION=2 -I. -DNHYP -DLU ../generic/com_mpi.c In file included from ../generic/com_mpi.c:104: /opt/local/include/mpich-clang37/mpi.h:116:56: error: expected identifier static const MPI_Datatype mpich_mpi_char MPICH_ATTR_TYPE_T... ^ /opt/local/include/mpich-clang37/mpi.h:24:106: note: expanded from macro 'MPICH_ATTR_TYPE_TAG' ...__attribute__((type_tag_for_datatype(MPI,type))) ^ <command line>:1:13: note: expanded from here #define MPI 1 ^ ----- and then there is a sequence of similar messages, all regarding mpi.h. The compilation halts after 20 messages.
I originally tried this with mpich-default, with the same result. I wondered if it had to do with an incompatibility with clang, so I installed mpich-clang37 @3.1.4_1+gcc49, with the above result.
The same code still runs on current MPICH and MVAPICH installations on several systems.
Thanks for your help, Ben
-- Prof. Benjamin Svetitsky Phone: +972-3-640 8870 School of Physics and Astronomy Fax: +972-3-640 7932 Tel Aviv University E-mail: [email protected] 69978 Tel Aviv, Israel WWW: http://julian.tau.ac.il/bqs
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
