Re: [mpich-discuss] Problems running MPICH jobs under SLURM
Hi Markus, On 06/02/2013 04:31 AM, Markus Geimer wrote:
Markus: does this happen only with SLURM or can you reproduce this without SLURM as well?
It seems to happen only when hydra queries the host list from SLURM. I tried executing two different setups on the head node, both listing two compute nodes in a hostfile:
1) mpiexec -f hostfile -n 4 ./hello
Since the SLURM PAM module was disabled, SSH login to the nodes was possible and the job run as expected, with two ranks on each node. SLURM's sinfo showed both nodes as state 'idle' and the HYDRA_DEBUG output said '--rmk user --launcher ssh'.
That sounds good.
2) mpiexec -f hostfile -rmk slurm -n 4 ./hello
This job ran as well, with the nodes allocated via SLURM and shown as 'alloc'. Debug output: '--rmk slurm --launcher slurm'.
Specifying a hostfile with mpiexec within a SLURM batch job also worked, but that's obviously not what you normally want to do...
Hmm. -f hostfile and -rmk slurm are contradictory options, since both are just ways to get the host list. This should throw an error. I'll add that into Hydra.
Hope this helps. If there is anything else I should try out to help tracking down the issue, please let me know.
I'm still trying to find the exact option that fails. Can you try the following: # Use the slurm launcher, and user-specified resources % mpiexec -f hostfile -launcher slurm -n 4 ./hello # Use the ssh launcher, and user-specified resources % mpiexec -f hostfile -launcher ssh -n 4 ./hello # Use the ssh launcher, and slurm-specified resources % mpiexec -rmk slurm -launcher ssh -n 4 ./hello # Use the slurm launcher, and slurm-specified resources % mpiexec -rmk slurm -launcher slurm -n 4 ./hello At least one of them should throw the error you reported. -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
