Re: [mpich-discuss] gather, send
Is the send_buffer allocated to be large enough to hold max_buff on all ranks? Is gsend_buffer large enough to hold max_buff * nprocs? Is the rank 1, not rank 0, the root? On May 1, 2013, at 7:16 PM, Ryan Crocker wrote:
i'm just checking just the gather call, and the gsend_buffer from the gather call is still empty:
max_buff is now the largest core domain.
print*,max_buff -> 24750
call MPI_GATHER(send_buffer, max_buff, MPI_REAL, gsend_buffer, max_buff, MPI_REAL, iroot, comm, ierr)
a print out of the send_buffer and the gsend_buffer where it should have non-zero terms.
print*,irank,i,j,k,send_buffer(i,j,k),gsent_buffer(i,j,k) ->
1 6 50 6 0.0000000000000000 0.0000000000000000 1 7 50 6 0.0000000000000000 0.0000000000000000 1 8 50 6 0.0000000000000000 0.0000000000000000 1 9 50 6 0.0000000000000000 0.0000000000000000 1 10 50 6 0.0000000000000000 0.0000000000000000 1 11 50 6 0.0000000000000000 0.0000000000000000 1 12 50 6 0.0000000000000000 0.0000000000000000 1 13 50 6 0.0000000000000000 0.0000000000000000 1 14 50 6 0.0000000000000000 0.0000000000000000 1 15 50 6 0.0000000000000000 0.0000000000000000 1 16 50 6 0.0000000000000000 0.0000000000000000 1 17 50 6 0.0000000000000000 0.0000000000000000 1 18 50 6 0.0000000000000000 0.0000000000000000 1 19 50 6 0.0000000000000000 0.0000000000000000 1 20 50 6 0.0000000000000000 0.0000000000000000 1 21 50 6 0.0000000000000000 0.0000000000000000 1 22 50 6 0.0000000000000000 0.0000000000000000 1 23 50 6 0.0000000000000000 0.0000000000000000 1 24 50 6 0.0000000000000000 0.0000000000000000 1 25 50 6 0.0000000000000000 0.0000000000000000 1 6 51 6 1.0000000000000000 0.0000000000000000 1 7 51 6 1.0000000000000000 0.0000000000000000 1 8 51 6 1.0000000000000000 0.0000000000000000 1 9 51 6 1.0000000000000000 0.0000000000000000 1 10 51 6 1.0000000000000000 0.0000000000000000 1 11 51 6 1.0000000000000000 0.0000000000000000 1 12 51 6 1.0000000000000000 0.0000000000000000 1 13 51 6 1.0000000000000000 0.0000000000000000 1 14 51 6 1.0000000000000000 0.0000000000000000 1 15 51 6 1.0000000000000000 0.0000000000000000 1 16 51 6 1.0000000000000000 0.0000000000000000 1 17 51 6 1.0000000000000000 0.0000000000000000 1 18 51 6 1.0000000000000000 0.0000000000000000 1 19 51 6 1.0000000000000000 0.0000000000000000 1 20 51 6 1.0000000000000000 0.0000000000000000 1 21 51 6 1.0000000000000000 0.0000000000000000 1 22 51 6 1.0000000000000000 0.0000000000000000 1 23 51 6 1.0000000000000000 0.0000000000000000 1 24 51 6 1.0000000000000000 0.0000000000000000 1 25 51 6 1.0000000000000000 0.0000000000000000 1 6 52 6 0.0000000000000000 0.0000000000000000 1 7 52 6 0.0000000000000000 0.0000000000000000 1 8 52 6 0.0000000000000000 0.0000000000000000 1 9 52 6 0.0000000000000000 0.0000000000000000 1 10 52 6 0.0000000000000000 0.0000000000000000 1 11 52 6 0.0000000000000000 0.0000000000000000 1 12 52 6 0.0000000000000000 0.0000000000000000 1 13 52 6 0.0000000000000000 0.0000000000000000 1 14 52 6 0.0000000000000000 0.0000000000000000 1 15 52 6 0.0000000000000000 0.0000000000000000 1 16 52 6 0.0000000000000000 0.0000000000000000 1 17 52 6 0.0000000000000000 0.0000000000000000 1 18 52 6 0.0000000000000000 0.0000000000000000 1 19 52 6 0.0000000000000000 0.0000000000000000 1 20 52 6 0.0000000000000000 0.0000000000000000 1 21 52 6 0.0000000000000000 0.0000000000000000 1 22 51 6 1.0000000000000000 0.0000000000000000 1 23 51 6 1.0000000000000000 0.0000000000000000 1 24 51 6 1.0000000000000000 0.0000000000000000 1 25 51 6 1.0000000000000000 0.0000000000000000 1 6 52 6 0.0000000000000000 0.0000000000000000 1 7 52 6 0.0000000000000000 0.0000000000000000 1 8 52 6 0.0000000000000000 0.0000000000000000 1 9 52 6 0.0000000000000000 0.0000000000000000 1 10 52 6 0.0000000000000000 0.0000000000000000 1 11 52 6 0.0000000000000000 0.0000000000000000 1 12 52 6 0.0000000000000000 0.0000000000000000 1 13 52 6 0.0000000000000000 0.0000000000000000 1 14 52 6 0.0000000000000000 0.0000000000000000 1 15 52 6 0.0000000000000000 0.0000000000000000 1 16 52 6 0.0000000000000000 0.0000000000000000 1 17 52 6 0.0000000000000000 0.0000000000000000 1 18 52 6 0.0000000000000000 0.0000000000000000 1 19 52 6 0.0000000000000000 0.0000000000000000 1 20 52 6 0.0000000000000000 0.0000000000000000 1 21 52 6 0.0000000000000000 0.0000000000000000 1 22 52 6 0.0000000000000000 0.0000000000000000 1 23 52 6 0.0000000000000000 0.0000000000000000 1 24 52 6 0.0000000000000000 0.0000000000000000 1 25 52 6 0.0000000000000000 0.0000000000000000
On May 1, 2013, at 5:06 PM, Rajeev Thakur wrote:
Just before the call to gather, check the value of send_count and check that send_buffer is not all zeros.
send_count has to be the same on all ranks. Otherwise you have to use Gatherv.
On May 1, 2013, at 7:03 PM, Ryan Crocker wrote:
that's where i checked it with and it's min and max are still zero. I just amended it so that each send buffer from the different cores are the same size and when i check it on the root gsend_buffer is still incorrect.
On May 1, 2013, at 5:00 PM, Rajeev Thakur wrote:
gsend_buffer will be valid only on the root.
On May 1, 2013, at 6:55 PM, Ryan Crocker wrote:
I just looked at the gsend_buffer, that's actually all zeros as well, and each send_buffer is not. So i think my problem is there.
On May 1, 2013, at 4:47 PM, Rajeev Thakur wrote:
The count passed to MPI_Scatter should be the local size, i.e., the amount that gets sent to each process. Looks like what is being passed is the global size.
On May 1, 2013, at 6:21 PM, Ryan Crocker wrote:
Hi all,
So i don't know what the issue with this code snippet is but i cannot get the scatter call to work. When i print out the recieve_buffer it comes out as all zeros. The counters without the underscore are the core domains, with the o, the global domains.
rec_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1) send_count = (imax_-imin_+1)*(jmax_-jmin_+1)*(kmax_-kmin_+1)
call MPI_GATHER (send_buffer, send_count, MPI_REAL, gsend_buffer, send_count, MPI_REAL, iroot, comm, ierr)
rec_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1) send_count = (imaxo-imino+1)*(jmaxo-jmino+1)*(kmaxo-kmino+1)
call MPI_SCATTER (gsend_buffer, send_count, MPI_REAL, recieve_buffer, rec_count, MPI_REAL, iroot, comm, ierr)
thanks for the help.
Ryan Crocker University of Vermont, School of Engineering Mechanical Engineering Department [email protected]
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
Ryan Crocker University of Vermont, School of Engineering Mechanical Engineering Department [email protected] 315-212-7331
participants (1)
Rajeev Thakur
