Problems with running make
I am struggling with running make on MPICH, V3.1. I believe that ./configure went well but I do not understand what caused the errors in make. I thought it may be associated with the fortran compile but I have F77 installed (though somewhat confused whether fortran 90 is also installed). The README file suggested that I send an email to this list with nominated four text files attached. The end of the m.txt file is included here for easy access, full details are attached... CC src/mpi/topo/nhb_alltoallw.lo CC src/binding/f90/create_f90_int.lo CC src/binding/f90/create_f90_real.lo src/binding/f90/create_f90_real.c: In function 'PMPI_Type_create_f90_real': src/binding/f90/create_f90_real.c:73: error: expected expression before ',' token src/binding/f90/create_f90_real.c:74: error: expected expression before ',' token make[2]: *** [src/binding/f90/create_f90_real.lo] Error 1 make[2]: Leaving directory `/inv/mpich-3.1' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/inv/mpich-3.1' make: *** [all] Error 2 I look forward to any suggestions any of you may have. Regards, Ron
participants (1)
Ron Palmer
