Re: [mpich-discuss] How to use non-blocking send/receive without calling MPI_Wait
On Tue, Apr 7, 2015 at 2:37 AM, Lei Shi <[email protected]> wrote:
Hi Huiwei and Jeff,
I use hybrid OpenMP/MPI to do overlap communication. So I put all communication in one dedicated OpenMP thread and computation in the other thread. For this case, I'm using intel MPI library. Probably I did some mistakes
One version of my code using one dedicated thread to do messaging is like this
/* hybrid mpi/openmp overlap **/template<typename T>void CPR_NS_3D_Solver<T>::UpdateRes(T**q, T**res){ int thread_id,n_thread; int sol_rev_flag=0,grad_rev_flag=0;
// Explicitly disable dynamic teams omp_set_dynamic(0); // Use 2 threads for all consecutive parallel regions omp_set_num_threads(2); #pragma omp parallel default(shared) private(thread_id) { thread_id=omp_get_thread_num(); n_thread=omp_get_num_threads();
/** communication thread **/ if(thread_id==1){ SendInterfaceSol(); RevInterfaceSol();#pragma omp flush sol_rev_flag=1;#pragma omp flush(sol_rev_flag) }
/** computation thread **/ if(thread_id==0){ ResFromDivInvisFlux(q,res); //local computation #pragma omp flush(sol_rev_flag) while(sol_rev_flag!=1){ #pragma omp flush(sol_rev_flag) }#pragma omp flush ResFromFluxCorrection(q,res); //depends on interface sol } }//end of omp }
void CPR_NS_3D_Solver<T>::SendInterfaceSol(){ uint *n_if_to_proc=this->grid_->num_iface_proc; uint **if_to_proc=this->grid_->snd_iface_proc; uint **rev_if_to_f=this->grid_->rev_iface_proc;
int tag=52; for(int p2=0;p2<_n_proc;++p2){ if(p2!=_proc_id){ int nif=n_if_to_proc[p2]; //pack data to send ....
/** * Exchange interface sol **/ int n_proc_exchange=0; for(int z=0;z<_n_proc;++z){ int nif=n_if_to_proc[z];
//send data if(nif>0){ MPI_Isend(&snd_buf_[z][0],n_buf_[z],MPI_DOUBLE,z,tag, MPI_COMM_WORLD, &s_sol_req_[n_proc_exchange]); MPI_Irecv(&rev_buf_[z][0],n_buf_[z],MPI_DOUBLE,z,tag, MPI_COMM_WORLD, &r_sol_req_[n_proc_exchange]); n_proc_exchange++; } }
template<typename T> void CPR_NS_3D_Solver<T>::RevInterfaceSol(){ uint *n_if_to_proc=this->grid_->num_iface_proc; uint **if_to_proc=this->grid_->snd_iface_proc; uint **rev_if_to_f=this->grid_->rev_iface_proc;
//wait if(n_proc_exchange_>0){ MPI_Waitall(n_proc_exchange_,s_sol_req_,MPI_STATUS_IGNORE); MPI_Waitall(n_proc_exchange_,r_sol_req_,MPI_STATUS_IGNORE); }
/** store to local data structure **/ for(int z=0;z<_n_proc;++z){ int nif=n_if_to_proc[z];
if(nif>0){
//unpacking .... } }
Sincerely Yours,
Lei Shi ---------
On Fri, Apr 3, 2015 at 4:37 PM, Jeff Hammond <[email protected]> wrote:
As far as I know, Ethernet is not good at making asynchronous progress in hardware the way e.g. InfiniBand is. I would have thought that a dedicated progress thread would help, but it seems you tried that. Did you use your own progress thread or MPICH_ASYNC_PROGRESS=1?
Jeff
On Fri, Apr 3, 2015 at 10:10 AM, Lei Shi <[email protected]> wrote:
Huiwei,
Thanks for your email. Your answer leads to my another question about asynchronous MPI communication.
I'm trying to do an overlapped communication/computing to speedup my MPI code. I read some papers comparing some different approaches to do the overlapped communication. The "naive" overlapped communication implementation, which only use non-blocking mpi Isend/Irecv and the hybrid approach using OpenMP and MPI together. In the hybrid approach, a separated thread is use to do all non-blocking communications. Just exactly as you said, the results indicate that current MPI implementations do not support true asynchronous communication.
If I use the naive approach, my code with non-blocking or blocking send/recv gives me almost the same performance in term of Wtime. All communications are postponed to MPI_Wait.
I have tried calling mpi_test to push library to do communication during iterations. And try to use a dedicated thread to do communication and the other thread to do computing only. However, the performance gains are very small or no gain at all. I'm wondering it is due to the hardware. The cluster I tested uses 10G Ethernet card.
Best,
Lei Shi
On Fri, Apr 3, 2015 at 8:49 AM, Huiwei Lu <[email protected]> wrote:
Hi Lei,
As far as I know, all current MPI implementations do not support true asynchronous communication for now. i.e., If there is no MPI calls in your iterations, MPICH will not be able to make progress on communication.
One solution is to poll the MPI runtime regularly to make progress by inserting MPI_Test to your iteration (even though you do not want to check the data).
Another solution is to enable MPI's asynchronous progress thread to make progress for you.
-- Huiwei
On Thu, Apr 2, 2015 at 11:44 PM, Lei Shi <[email protected]> wrote:
Hi Junchao,
Thanks for your reply. For my case, I don't want to check the data have been received or not. So I don't want to call MPI_Test or any function to verify it. But my problem is like if I ignore calling the MPI_Wait, just call Isend/Irev, my program freezes for several sec and then continues to run. My guess is probably I messed up the MPI library internal buffer by doing this.
On Thu, Apr 2, 2015 at 7:25 PM, Junchao Zhang <[email protected]> wrote:
Does MPI_Test fit your needs?
--Junchao Zhang
On Thu, Apr 2, 2015 at 7:16 PM, Lei Shi <[email protected]> wrote:
I want to use non-blocking send/rev MPI_Isend/MPI_Irev to do communication. But in my case, I don't really care what kind of data I get or it is ready to use or not. So I don't want to waste my time to do any synchronization by calling MPI_Wait or etc API.
But when I avoid calling MPI_Wait, my program is freezed several secs after running some iterations (after multiple MPI_Isend/Irev callings), then continues. It takes even more time than the case with MPI_Wait. So my question is how to do a "true" non-blocking communication without waiting for the data ready or not. Thanks.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Lei Shi
