Re: [mpich-discuss] too many communicators
How many communicators are created by the loops containing these statements? Could it be more than the limit?
psymbfact.c: MPI_Comm_dup ((*symb_comm), &(commLvls[i])); psymbfact.c: MPI_Comm_split ((*symb_comm), col, key, &(commLvls[ind]) );
~Jim. On 12/13/12 12:19 PM, Jeff Hammond wrote:
It's far from conclusive, but I went through the SuperLU_dist source and it seems there is proper symmetry between communicator creation and destruction.
$ for f in create dup split free ; do grep MPI_Comm_$f *.c ; done superlu_grid.c: MPI_Comm_create( Bcomm, superlu_grp, &grid->comm ); psymbfact.c: MPI_Comm_dup ((*symb_comm), &(commLvls[i])); pdgssvx.c: MPI_Comm_split (grid->comm, col, key, &symb_comm ); psymbfact.c: MPI_Comm_split ((*symb_comm), col, key, &(commLvls[ind]) ); pzgssvx.c: MPI_Comm_split (grid->comm, col, key, &symb_comm ); superlu_grid.c: MPI_Comm_split(grid->comm, myrow, mycol, &(grid->rscp.comm)); superlu_grid.c: MPI_Comm_split(grid->comm, mycol, myrow, &(grid->cscp.comm)); pdgssvx.c: MPI_Comm_free (&symb_comm); psymbfact.c: MPI_Comm_free (&(commLvls[i])); psymbfact.c: MPI_Comm_free ( &(commLvls[ind]) ); pzgssvx.c: MPI_Comm_free (&symb_comm); superlu_grid.c: MPI_Comm_free( &grid->rscp.comm ); superlu_grid.c: MPI_Comm_free( &grid->cscp.comm ); superlu_grid.c: MPI_Comm_free( &grid->comm );
Jeff
On Thu, Dec 13, 2012 at 9:40 AM, Jim Dinan <[email protected]> wrote:
Hi Jack,
It sounds like your application, or maybe the solver, is leaking communicators somewhere. If you configure with --enable-g=handlealloc (or --enable-g=all), MPICH will issue warnings about leaked MPI objects when your program exits.
~Jim.
On 12/12/12 6:47 PM, Dave Goodell wrote:
On Dec 13, 2012, at 5:23 AM GMT+09:00, Jack Lee wrote:
What I'd like to determine first is whether fault is on my side (e.g. perhaps I'm not calling the clean-up routines properly). Is there a way to find out how many context id's are in use at a given point?
If your MPICH was configured with "--enable-g=log" (or a superset thereof, such as "=all"), then you can add the following prototype into your application and invoke this function to get a string showing the current bit-vector state on a given process:
----8<---- static char *MPIR_ContextMaskToStr(void); ----8<----
see src/mpi/comm/commutil.c for more insight into how this works and what it's actually telling you. This wiki node also has some useful (and only slightly stale) information:
http://wiki.mpich.org/mpich/index.php/Communicators_and_Context_IDs
I wish I had a better option for you, but without just rolling up your sleeves and hacking on the MPICH code, this is about as good as you're likely to get.
The next best approach would probably be to trap all the communicator creation/destruction calls that you can think of (see the MPI-2.2 standard, chapter 6) via the PMPI_ profiling interface and log the invocations to look for a mismatch.
-Dave
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jim Dinan
