Re: [mpich-discuss] mpiexec ignoring host setting in configfile
On 06/22/2017 11:16 AM, Alexander Rast wrote:
On Thu, Jun 22, 2017 at 4:14 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
-host(s) is a global option. You can only specify it once.
? This doesn't make sense to me. Example 8.13 from the MPI specification has:
mpiexec myprog infile1 : myprog infile2 : myprog infile3, corresponding to Form A
mpiexec {<above arguments>} : {...} : {...} : ... : { ...}
which invokes potentially multiple programs with different arguments (of which host is one)
and then mentions that Form B: mpiexec -configfile <filename> has lines of the form separated by the colons in Form A.
So there's no reason, I would think, that a Form B file can't have multiple lines with different hosts specified for the same executable.
The reason is that Hydra does not support it. You are allowed one -host(s) argument. If you want to submit a patch to allow more than one instance, we will consider it.
Further, your configfile does not make much sense since your are using the same program on both lines. You could rather just do:
mpiexec -n 4 -ppn 2 -hosts Shakespeare,Burns ./mpi_io_test
I have not seen the -ppn switch listed anywhere. What does this do? Is this intended to be a 'limit number of processes to n on the hosts specified?
$ mpiexec -h | grep ppn -ppn processes per node
Notwithstanding this isn't what is needed anyway, because what if I want specifically to run at most 2 processes on Shakespeare but 5 on Burns (imagine, for example, that Shakespeare is already loaded with other processes, so I need to limit it for the executable in concern)?
Irregular mappings like this can be done with a hostfile.
In any case the point is, using the same program on both lines to me seems straightforward enough given that there are numerous instances (as ex. 8.13 above) where various switches and options might be different.
I note also that -hosts is different from the -host switch listed as pre-defined for mpiexec.
Hydra supports both -host and -hosts. They mean the same thing.
In my case we have a system where the objective is to direct specific instances of an application or possibly several to specific hosts - so that the mapping can be fixed. In the limit this might consist of -n 1 -host <x> <executable> lines, each directing a specific instance of the executable to a specific host.
Again, this will not work with today's Hydra. I would suggest playing around some more with the available options to see if another solution might work for your use-case. Ken _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
