Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
Sorry, I misinterpreted/misread your question or otherwise acted stupidly. I think http://www.linfo.org/su.html and http://www.howtogeek.com/111479/htg-explains-whats-the-difference-between-su... answer everything in detail, but "sudo" and "su" give you the same environment. Jeff On Thu, Jun 13, 2013 at 9:36 AM, Lee, Eibhlin <[email protected]> wrote:
In that case there are definitely misleading guides out there. http://www.cyberciti.biz/faq/ubuntu-linux-root-password-default-password/ This implies that sudo bash does log you in as root user. Either my second question confused you; it wasn't the right question to ask; or the guide I linked to is completely wrong. Eibhlin ________________________________________ From: [email protected] [[email protected]] on behalf of Jeff Hammond [[email protected]] Sent: 13 June 2013 15:27 To: [email protected] Subject: Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
No, of course the root environment is not the same as your user environment. There are plenty of "intro to Linux" resources online if you need this kind of information.
If you want your user environment as root, which I don't think is particularly safe or a good idea, you can set it with "source ~${yourusername}/.${yourshell}rc" where yourusername is $USERNAME when you are not root and yourshell is $SHELL when you are not root.
The better option is to figure out what environment variables you need to set in the mpiexec environment that are currently defined in your user environment and set those manually.
Jeff
On Thu, Jun 13, 2013 at 9:15 AM, Lee, Eibhlin <[email protected]> wrote:
Jeff, Does that put you into the same environment as sudo bash? Because I have already tried that with no success. Eibhlin ________________________________________ From: [email protected] [[email protected]] on behalf of Jeff Hammond [[email protected]] Sent: 13 June 2013 13:58 To: [email protected] Subject: Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
Just su to root instead of using sudo.
Jeff
On Thu, Jun 13, 2013 at 6:56 AM, Lee, Eibhlin <[email protected]> wrote:
Hello all,
I am trying to use two raspberry-pi to sample and then process some data. The first process samples while the second processes and vice versa. To do this I use gpio and also mpich-3.0.4 with the process manager smpd. I have successfully run cpi on both machines (from the master machine). I have also managed to run a similar program but without the MPI, this involved compiling with gcc and when running putting sudo in front of the binary file.
When I combine these two processes I get various error messages. For input: mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: Can't open /dev/mem Did you forget to use 'sudo .. ?'
For input: sudo mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: sudo: mpiexec: Command not found
I therefore put mpiexec into /usr/bin
now for input: sudo mpiexec -phrase cat -machinefile machinefile -n 2 ~/main the error is: Can't open /dev/mem Did you forget to use 'sudo .. ?'
Does anyone know how I can work around this? Thanks, Eibhlin
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
