Re: [mpich-discuss] question in MPI_Info_get
Hi Junchao, Thank you for your reply. Okay, so it sounds like in the current dominant implementation I can treat valuelen as “length of the buffer, including a space for the null terminator”. If anyone could provide a good explanation of the spec it would be great. Best, Hajime
On Feb 2, 2015, at 2:54 PM, Junchao Zhang <[email protected]> wrote:
Hi, Hajime, MPI spec also says "valuelen is the number of characters available in value". So it seems if you should pass valuelen = 4 if value is a buffer of 4 bytes. I am also confused by "In C, valuelen should be one less than the amount of allocated space to allow for the null terminator". So I leave the question for others. Interestingly, for MPI_Info_get_valuelen(), MPI spec says "The length returned in C does not include the end-of-string".
BTW, I found MPICH and OpenMPI have the same behavior.
--Junchao Zhang
On Sun, Feb 1, 2015 at 12:13 AM, Hajime Fujita <[email protected]> wrote: Hello,
I came across some question about a behavior of MPI_Info_get in MPICH.
If I knew the size of the value, what should I pass to MPI_Info_get as `valuelen`? Suppose I have 3-byte value in the info object, and I allocate 4-byte buffer including a space for null-termination. Then I think I should specify 3 as valuelen to retrieve the whole value, as the MPI-3 specifications says "In C, valuelen should be one less than the amount of allocated space to allow for the null terminator.”
However, when I run the attached program in MPICH 3.1.1, I get: $ ./test key found: vaule=va # The last character ‘l’ is missing
If I specify `sizeof(buff)` as valuelen, it shows “val” correctly.
So apparently MPICH thinks valuelen includes null terminator. Am I missing anything, or any misunderstanding here?
Thank you in advance, Hajime
-- Hajime Fujita Postdoctoral Scholar, Large-Scale Systems Group Department of Computer Science, The University of Chicago http://www.cs.uchicago.edu/people/hfujita _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Hajime Fujita
