Re: [mpich-discuss] MPI-IO bug
They are reasonable doubts. I tested this patch against test/mpi/io/resized.c and src/mpi/romio/test/hindexed.c Could you run tests (both MPI and ROMIO) and see if the patch failed for any tests? At least we will have an idea if it breaks anything first. Wei-keng On May 1, 2014, at 10:53 AM, Rob Latham wrote:
On 04/09/2014 02:52 PM, Wei-keng Liao wrote:
The patch below can fix this problem. Hope it does not break other tests.
I'm uncertain about this patch...
Index: adio/common/ad_read_coll.c
it should have been in the write path, correct ?
@@ -368,13 +368,16 @@ #endif if (file_ptr_type == ADIO_INDIVIDUAL) { /* Wei-keng reworked type processing to be a bit more efficient */ + for (i=0; i<flat_file->count; i++) /* skip blocklens[] == 0 */ + if (flat_file->blocklens[i] > 0) break; +
the flat_file->blocklens[] array might contain a UB and LB marker. The marker will be stored in the flattened representation with a zero-length element at a particular offset. So if you resize a type, your flattened representation would be like this: (offset: 50, length: 0), (offset: 100, length: 1024), (offset: 200, length: 0)
furthermore, ADIOI_Optimize_flatten will coalesce multiple zero-length elements into one, but will leave the first and last elements alone.
offset = fd->fp_ind - disp; - n_filetypes = (offset - flat_file->indices[0]) / filetype_extent; + n_filetypes = (offset - flat_file->indices[i]) / filetype_extent;
doesn't this mess up tiling of the file view?
==rob
offset -= (ADIO_Offset)n_filetypes * filetype_extent; /* now offset is local to this extent */
/* find the block where offset is located, skip blocklens[i]==0 */ - for (i=0; i<flat_file->count; i++) { + for (; i<flat_file->count; i++) { ADIO_Offset dist; if (flat_file->blocklens[i] == 0) continue; dist = flat_file->indices[i] + flat_file->blocklens[i] - offset;
Wei-keng
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Wei-keng Liao
