Re: [mpich-discuss] fail to configure mpich 3.1.4 use gcc 5.2.0
Are you using fortran-5 as well? If you don't need fortran, you can disable it by passing --disable-fortran to configure. Yanfei Guo Postdoctoral Appointee MCS Division, ANL On 10/19/15, 8:32 PM, "广州刘丹" <[email protected]> wrote:
Hello, everyone: After I upgrade gcc from 4.4.7 to 5.2.0 under oracle linux 6.7, the system can't pass config mpich 3.1.4 when I run:
./configure -prefix=/usr/local/share/mpich-3.1.4/ |& tee c.txt
below is error message: configure: error: Unable to configure with Fortran support because configure could not determine the size of a Fortran INTEGER. Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes of a Fortran INTEGER
When I use gcc 4.4.7, there's no error to make mpich 3.1.4.
and below is the process how to upgrade gcc: wget ftp://ftp.gnu.org/gnu/gcc/gcc-5.2.0/gcc-5.2.0.tar.bz2 tar -jxvf gcc-5.2.0.tar.bz2 cd gcc-5.2.0 ./contrib/download_prerequisites cd .. mkdir /usr/local/share/gcc-5.2.0 ./gcc-5.2.0/configure --prefix=/usr/local/share/gcc-5.2.0/ --disable-multilib --enable-languages=c,c++,objc,obj-c++,java,fortran make -j4 sudo make install
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Guo, Yanfei
