Re: [mpich-discuss] MPID_nem_tcp_init(377)... gethostbyname failed, mac (errno 1)
It also works with en0: lcebaman@mac~/$ mpiexec -iface en0 -n 4 ./hello Hello world from process 0 of 4 Hello world from process 3 of 4 Hello world from process 1 of 4 Hello world from process 2 of 4 And that is what my ifconfig says: lcebaman@mac~/$ ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=3<RXCSUM,TXCSUM> inet6 ::1 prefixlen 128 inet 127.0.0.1 netmask 0xff000000 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 nd6 options=1<PERFORMNUD> gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280 stf0: flags=0<> mtu 1280 en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 28:cf:e9:1f:cf:13 inet6 fe80::2acf:e9ff:fe1f:cf13%en0 prefixlen 64 scopeid 0x4 inet 172.20.170.189 netmask 0xfffff000 broadcast 172.20.175.255 nd6 options=1<PERFORMNUD> media: autoselect status: active en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=60<TSO4,TSO6> ether 32:00:17:4d:80:20 media: autoselect <full-duplex> status: inactive en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500 options=60<TSO4,TSO6> ether 32:00:17:4d:80:21 media: autoselect <full-duplex> status: inactive p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304 ether 0a:cf:e9:1f:cf:13 media: autoselect status: inactive bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 options=63<RXCSUM,TXCSUM,TSO4,TSO6> ether 2a:cf:e9:f1:ef:00 Configuration: id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0 maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200 root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0 ipfilter disabled flags 0x2 member: en4 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 5 priority 0 path cost 0 member: en5 flags=3<LEARNING,DISCOVER> ifmaxaddr 0 port 6 priority 0 path cost 0 nd6 options=1<PERFORMNUD> media: <unknown type> status: inactive Cheers, Luis On 3 Mar 2014, at 22:24, Luis Cebamanos <[email protected]> wrote:
Hi Reuti,
I have done what you suggested and it WORKS with the wireless off
lcebaman@mac~/$ mpiexec -iface lo0 -n 4 ./hello Hello world from process 0 of 4 Hello world from process 3 of 4 Hello world from process 1 of 4 Hello world from process 2 of 4
What is the problem here then?
Cheers, Luis On 3 Mar 2014, at 14:54, Reuti <[email protected]> wrote:
Am 03.03.2014 um 11:29 schrieb Luis Cebamanos:
I have also noticed that working without any internet connection does not work either.
Just for curiosity:
$ mpiexec -iface lo0 -n 4 ./foo
-- Reuti
On 3 Mar 2014, at 09:53, Luis Cebamanos <[email protected]> wrote:
Hi there,
I’ve got more news. The last IP that I showed in my last email it turns out that works OKAY, however now that I am back to the office and working on the wireless, it does not work. And that is the result of nslookup:
lcebaman@mac~/Projects/SPRINT$ nslookup localhost Server: 129.215.205.191 Address: 129.215.205.191#53
Name: localhost.ed.ac.uk Address: 127.0.0.1
lcebaman@mac~/Projects/SPRINT$ nslookup mac Server: 129.215.205.191 Address: 129.215.205.191#53
** server can't find mac: NXDOMAIN
Any thoughts?
Cheers, Luis
On 1 Mar 2014, at 19:40, l.cebamanos <[email protected]> wrote:
Well, is not fixed. Its just the one I got here, but it changes. Any ideas of how to fix this?
-------- Original message -------- From: Reuti <[email protected]> Date:01/03/2014 17:38 (GMT+00:00) To: [email protected] Subject: Re: [mpich-discuss] MPID_nem_tcp_init(377)... gethostbyname failed, mac (errno 1)
Am 01.03.2014 um 17:58 schrieb Luis Cebamanos:
Here it is the output of those commands:
lcebaman@mac~/$ nslookup localhost Server: 192.168.1.1 Address: 192.168.1.1#53
Name: localhost Address: 127.0.0.1
lcebaman@mac~/$ nslookup mac Server: 192.168.1.1 Address: 192.168.1.1#53
Name: mac Address: 192.168.1.127
Is this a fixed address you get everytime? You could add it to /etc/hosts.
Interesting that MPICH throws an error about resolving "mac", although DNS is working.
-- Reuti
lcebaman@mac~/$ hostname mac
On 28 Feb 2014, at 23:35, Reuti <[email protected]> wrote:
Am 28.02.2014 um 14:39 schrieb Luis Cebamanos:
Hi Pavan,
Yes, that is the output:
$ cat /etc/hosts ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost 255.255.255.255 broadcasthost ::1 localhost fe80::1%lo0 localhost
What is the output of:
$ nslookup localhost $ nslookup mac $ hostname
AFAICS your machine has no domainname, otherwise it would show up in the MPICH error message after "mac".
-- Reuti
On 28/02/14 13:35, Balaji, Pavan wrote:
$ cat /etc/hosts
-- The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Luis Cebamanos
