Re: [mpich-discuss] Error when using mpiexec whith mpich-3.04
statut has to be allocated of size MPI_STATUS_SIZE not nb_pr. On Nov 21, 2013, at 10:29 AM, vincent russier <[email protected]> wrote:
I include the trial code as an attached file. In the meantime, I tried to run with increasing number of processes; I realized that it works without error messages if np >= 8 and fails otherwise.
Thanks, VR
Le jeudi 21 novembre 2013 à 10:03 -0600, Wesley Bland a écrit :
Can you include the minimum working example? We need to see the code to know what's going wrong.
Thanks, Wesley
On Nov 21, 2013, at 10:00 AM, vincent russier <[email protected]> wrote:
I have installed mpich-3.04 on a computer powered by linux. Everything seems to be OK. The example in f.90 runs correctecly without error mesages. When I try my own trial code (simply a send and a recv call) I get the following error mesage :
Assertion failed in file src/mpid/ch3/src/mpid_vc.c at line 140: MPIU_Object_get_ref((vcrt)) >= 0
The process which aborts is the one on which I use the recv instruction.
I have use mpiexec -n <n> ./trial.out
I have tried with ifort and gfortran compilers with the same result.
I have made the same install on another computer also powered by Linux with exactly the same result.
The 2 Linux are different: Fedora 19 and RedHat Enterprise 6.2
Thank you for your help. VR
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <test_mpi.f90>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rajeev Thakur
