Re: [mpich-discuss] MPI_Comm_Spawn causing zombies of hydra_pmi_proxy
PS: Just some additional information on compilers: so far I used icpc, when changing it to gcc-4.7.2 I still get the zombies. The only change in the linked libraries is an additional libdl.so.2 => /lib64/libdl.so.2 Any hint / idea? Best regards Silvan On 19.03.2013 10:47, Silvan Br�ndli wrote:
Dear Pavan,
in the attached example I use mpich3, but still I get the zombies. Is there something wrong with - my MPI function calls? (disconnect, finalize) - my linked libraries? (see below)
Thanks in advance! Best regards Silvan
ldd_hi linux-vdso.so.1 (0x00007fffa01ff000) libmpichcxx.so.10 => /opt/mpich3/lib/libmpichcxx.so.10 (0x00007fdfec0e4000) libmpich.so.10 => /opt/mpich3/lib/libmpich.so.10 (0x00007fdfebc6f000) libopa.so.1 => /opt/mpich3/lib/libopa.so.1 (0x00007fdfeba6d000) libmpl.so.1 => /opt/mpich3/lib/libmpl.so.1 (0x00007fdfeb868000) libaio.so.1 => /lib64/libaio.so.1 (0x00007fdfeb666000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fdfeb449000) libm.so.6 => /lib64/libm.so.6 (0x00007fdfeb14e000) libstdc++.so.6 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libstdc++.so.6 (0x00007fdfeae47000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fdfeac30000) libc.so.6 => /lib64/libc.so.6 (0x00007fdfea882000) libdl.so.2 => /lib64/libdl.so.2 (0x00007fdfea67e000) libgfortran.so.3 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libgfortran.so.3 (0x00007fdfea361000) libquadmath.so.0 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libquadmath.so.0 (0x00007fdfea12b000) /lib64/ld-linux-x86-64.so.2 (0x00007fdfec308000) librt.so.1 => /lib64/librt.so.1 (0x00007fdfe9f23000) ldd_main linux-vdso.so.1 (0x00007fffeb1ff000) libmpichcxx.so.10 => /opt/mpich3/lib/libmpichcxx.so.10 (0x00007f6fc797e000) libmpich.so.10 => /opt/mpich3/lib/libmpich.so.10 (0x00007f6fc7509000) libopa.so.1 => /opt/mpich3/lib/libopa.so.1 (0x00007f6fc7307000) libmpl.so.1 => /opt/mpich3/lib/libmpl.so.1 (0x00007f6fc7102000) libaio.so.1 => /lib64/libaio.so.1 (0x00007f6fc6f00000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f6fc6ce3000) libm.so.6 => /lib64/libm.so.6 (0x00007f6fc69e8000) libstdc++.so.6 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libstdc++.so.6 (0x00007f6fc66e1000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f6fc64ca000) libc.so.6 => /lib64/libc.so.6 (0x00007f6fc611c000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f6fc5f18000) libgfortran.so.3 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libgfortran.so.3 (0x00007f6fc5bfb000) libquadmath.so.0 => /usr/lib/gcc/x86_64-pc-linux-gnu/4.7.2/libquadmath.so.0 (0x00007f6fc59c5000) /lib64/ld-linux-x86-64.so.2 (0x00007f6fc7ba2000) librt.so.1 => /lib64/librt.so.1 (0x00007f6fc57bd000)
On 07.03.2013 17:23, Pavan Balaji wrote:
I just tried this with the mpich master and it seems to work correctly, and there are no zombie processes (though I reduced the number of iterations to 10000, instead of 200000). This was a problem in mpich once upon a time, but that was a few years ago. Are you using the latest version of mpich (3.0.2)?
-- Pavan
On 03/07/2013 09:44 AM US Central Time, Silvan Br�ndli wrote:
PS: The attached programs are a simplification of my code. They reproduce the zombie problem. Waiting for the 32k zombies takes a while... but I expect the same behaviour as with my original code.
Am I missing something when finishing the called program? I just use MPI_Comm_disconnect and MPI_Finalize.
Best regards Silvan
main.cpp
#include <mpi.h>;
int main(int argc, char *argv[]) { int myrank; int spawnerror; int value = 123; void *buf = &value; MPI_Comm child_comm;
if (MPI_Init(&argc,&argv)!=MPI_SUCCESS) { printf("MPI_Init failed"); }
MPI_Comm_rank(MPI_COMM_WORLD, &myrank);
char* hiargv[] = {"23",NULL}; for(int i = 1; i <= 200000; i++) { value = i; printf("Main before spawn %d\n",i); MPI_Comm_spawn("./hi",hiargv, 1, MPI_INFO_NULL, myrank, MPI_COMM_SELF, &child_comm, &spawnerror); MPI_Send(buf, 1, MPI_INTEGER, 0, 1, child_comm); MPI_Comm_disconnect(&child_comm); }
MPI_Finalize(); return 0; }
hi.cpp:
#include <mpi.h>;
int main(int argc, char** argv) { MPI_Comm parent; MPI_Status status; int err; int value = -1; void* buf= &value;
if (MPI_Init(&argc,&argv)!=MPI_SUCCESS) { printf("MPI_Init failed"); } MPI_Comm_get_parent(&parent); if (parent == MPI_COMM_NULL) printf("No parent!");
MPI_Recv(buf, 1, MPI_INTEGER, 0, MPI_ANY_TAG, parent, &status); MPI_Comm_disconnect(&parent); err = MPI_Finalize(); printf("hi finalized %d %d \n",err, value); return 0; }
On 07.03.2013 12:38, Silvan Br�ndli wrote:
Dear all,
again I have a question related to spawning processes. I understand the situation as follows:
My program A spawns program B. Program B spawns program C1, C2 ... C10000 ... Program Cx terminates correctly before Cx+1 is called, however returning 1 to mpiexec. To handle this I use the workaround as described in http://lists.mpich.org/pipermail/discuss/2013-February/000429.html
Now it looks like with every Spawn a "hydra_pmi_proxy" is started, the calling program is mpiexec. When the program Cx is finished this "hydra_pmi_proxy" remains as a zombie until the programs A, B and mpiexec are finished. When approx. 32k of those "hydra_pmi_proxy" exist I get some problems (too many processes or something similar).
What can I do to finish "hydra_pmi_proxy" while my programs A, B and mpiexec are still running?
I'm glad about every hint.
Best regards Silvan
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dipl.-Ing. Silvan Br�ndli Numerische Strukturanalyse mit Anwendungen in der Schiffstechnik (M-10) Technische Universit�t Hamburg-Harburg Schwarzenbergstra�e 95c 21073 Hamburg Tel. : +49 (0)40 42878 - 6187 Fax. : +49 (0)40 42878 - 6090 e-mail: [email protected] www : http://www.tuhh.de/skf 5th GACM Colloquium on Computational Mechanics http://www.tu-harburg.de/gacm2013
participants (1)
Silvan Brändli
