Installation problem
Hi, I am installing mpich 3.1.4 and the following the configure script I use: CC=/share/apps/intel/Compiler/11.0/081/bin/intel64/icc CXX=/share/apps/intel/Compiler/11.0/081/bin/intel64/icpc F77=/share/apps/intel/Compiler/11.1/072/bin/intel64/ifort FC=/share/apps/intel/Compiler/11.1/072/bin/intel64/ifort CPPFLAGS=-I/opt/torque/include LDFLAGS="-L/opt/torque/lib -L/opt/torque/lib64" ../mpich-3.1.4/configure --prefix=/share/apps/estools/mpich2/3.1.4/intel --enable-cxx --enable-fortran=all --enable-threads=multiple --with-thread-package=posix --enable-romio --with-pm=hydra --enable-shared --enable-static However I have two inquiries: I am installing it on a cluster with Torque PBS system and wish bind mpich against Torque. The configure output states that: checking tm.h usability... yes checking tm.h presence... yes checking for tm.h... yes checking for tm_init in -ltorque... yes But I do this by adding "CPPFLAGS=-I/opt/torque/include ", but do I have to repeat it for other flags (CFLAGS, CXXFLAGS, FFLAGS, FCFLAGS ...) ? After I perform make and make install, I proceed to make testing, but with a lot of this error: /share/apps/intel/Compiler/11.1/072/lib/intel64/libifport.so.5: undefined reference to `__intel_sse2_strlen' By some googling I found some hints that this can be resolved by adding the library libifcoremt.so, but when I add it to the LIBS parameter the configure script cannot even start. So what is the correct way to do this? Or is there any other solution? Thank you. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Eong Sheng Goh
