MPI_Abort not working with multinode jobs launched by hydra-3.2
Hi, We've encountered a problem with hydra-3.2 and Intel MPI 5.1.3.210 with multi-node MPI programs. A call to MPI_Abort results in the all MPI ranks running on the same node as the rank that called MPI_Abort to exit, but leaves the other ranks running. The program hangs on the other nodes interminably (at least until the time limit of the batch job is reached.) The behavior is the same with hydra-3.3a2. The problem does not exist when using hydra-3.1.4, all processes exit on all nodes. Reverting commit 9882227414439a4a79edd49ec10261742bb60108 fixes this problem with 3.2. The hydra shipped with Intel MPI does not exhibit this problem, but we are using an out-of-tree hydra as want the pbs launcher enabled. Is there a better mechanism for process cleanup other than reverting the patch above? Let me know if there's other information needed. Thanks, Doug _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Doug Johnson
