Re: [mpich-discuss] MPICH 2.1.5 checkpoint
But Do you know why after the first checkpoint the execution is frezzed during a time similar to the interval and, after that, a new checkpoint is triggered? Thank you. 2014-07-17 16:43 GMT+02:00 Bland, Wesley B. <[email protected]>:
You’ll probably need to somehow get your application to run longer then. Unfortunately, MPICH doesn’t support manually starting a checkpoint at this time.
On Jul 17, 2014, at 9:29 AM, Marcela Castro León <[email protected]> wrote:
Hi
I just want to make a one checkpoint during the execution, at the middle. We'are trying to observe the I/O to reduce the time using a parallel file system.
Thanks.
2014-07-17 13:30 GMT+02:00 Bland, Wesley B. <[email protected]>:
Is there a reason you can't just take the checkpoints less frequently?
On Jul 17, 2014, at 4:41 AM, "Marcela Castro León" <[email protected]> wrote:
Hi, I'm using mpich 2.1.5 compiled to use blcr checkpoint. I'm having problems with the checkpoint interval. When I execute: mpiexec -ckpointlib blcr -ckpoint-prefix /partnfs/mpichchk -ckpoint-interval 120 -f maquinas -n 16 ./bt.C.16
In fact, at the second 120, the execution is interrupted for checkpointing, but, as the checkpoint last more than 120 seconds, another checkpoint is immediately triggered instead of resuming the application. I only achieve to get a checkpoint by setting a checkpoint interval almost at the end of the execution but it is not useful.
How can I solve it? Besides, Is there a way to know how long is the checkpoint in time?
Thank you very much.
Marcela
mpiexec -info HYDRA build details: Version: 1.5 Release Date: Mon Oct 8 14:00:48 CDT 2012 CC: gcc CXX: c++ F77: gfortran F90: gfortran Configure options: '--disable-option-checking' '--prefix=/soft/mpich2/mpich2-1.5-blcr8.3' '--with-hydra-ckpointlib=blcr' '--with-blcr=/soft/blcr' '--enable-checkpointing' '--cache-file=/dev/null' '--srcdir=.' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= -L/soft/blcr/lib64 -L/soft/blcr/lib' 'LIBS=-lrt -lcr -lpthread ' 'CPPFLAGS= -I/SRC/mpi/mpich2-1.5/src/mpl/include -I/SRC/mpi/mpich2-1.5/src/mpl/include -I/SRC/mpi/mpich2-1.5/src/openpa/src -I/SRC/mpi/mpich2-1.5/src/openpa/src -I/SRC/mpi/mpich2-1.5/src/mpi/romio/include -I/soft/blcr/include' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs Checkpointing libraries available: blcr Demux engines available: poll select
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Marcela Castro León
