Re: [mpich-discuss] Hydra torque support issues
On 4/19/2013 3:10 AM, Pavan Balaji wrote:
On 04/18/2013 06:56 PM US Central Time, Bharath Ramesh wrote:
I'm particularly interested in whether mpiexec recognizes pbs as a possible launcher or not. If it recognizes pbs as a launcher, it should automatically select it where possible. It is using pbs as the launcher. The problem is with the setting of the session id for the forked hydra_pmi_proxy process on mother superior. Since the hydra_pmi_proxy process has the session id set to the bash process instead mpi_exec process. As a result of this torque is unable to track the resources consumed by the process. If you look at the openmpi processes their session id is set correctly and torque is able to track the resources consumed. Ah, OK. Sorry I lost track of the original issue in this email chain.
You are right about this issue. The basic problem is that launching proxies using tm_spawn tends to create a different session ID for them.
I've created a ticket to track it:
Not a problem. I understand using tm_spawn to launch proxies on the sister moms. To launch proxy on the mother superior one doesnt need to use tm_spawn, i.e., mpiexec can fork it on mother superior. I havent looked through the code to see if this is the issue. -- Bharath
participants (1)
Bharath Ramesh
