Re: [mpich-discuss] Errors building MPICH on Windows 10 Ubuntu subsystem
On Tue, Oct 11, 2016 at 6:55 PM, Balaji, Pavan <[email protected]> wrote:
Folks,
Damian is having a problem with autotools. This shouldn't have anything to do with GCC.
Sure, but "apt-get install mpich" is clearly the easy button here if we can make it work. Jeff
I'm curious as to why --disable-maintainer-mode is not helping since that option should essentially disable Makefile.in's dependency on Makefile.am/ configure.ac, etc. So even if the timestamps are broken, autotools should never be called.
-- Pavan
On Oct 12, 2016, at 6:06 AM, Jeff Hammond <[email protected]> wrote:
Because OpenCoarrays calls MPI from C, the possible Fortran ABI variation across major versions of GCC should not be an issue. Damian should be fine to apt-get install mpich and then use the resulting C library. I imagine that cafc='mpicc -cc=gfortran-6' would work, but this is just a guess.
Intel recently approved Windows 10. If I can get the VM for this, I'll try to debug this.
Jeff
On Tue, Oct 11, 2016 at 10:57 AM, Kenneth Raffenetti < [email protected]> wrote: mpicc and friends are wrappers around the regular gcc/g++/gfortran compilers. If you have the version you want listed first in your PATH, things will probably work as you want. You can test by running 'mpicc -show' or 'mpicc -version' and check the underlying compiler.
Ken
On 10/11/2016 12:22 PM, Rob Latham wrote:
On 10/11/2016 10:05 AM, Kenneth Raffenetti wrote: On 10/11/2016 09:45 AM, Damian Rouson wrote:
Also, if you have Ubuntu, can you simply apt-get install mpich? On this system, apt-get installs GCC 4.8. My goal is to support users of OpenCoarrays, which requires at least GCC 5.1.0 and preferably GCC 6.1.0. Is there a Debian dpkg file that I could use to install MPICH?
Yes, try 'apt-get install mpich'.
I think he's saying "apt-get install mpich" brings in gcc-4.8 as a dependency.
Perhaps "apt-get source mpich" or maybe with the "-b" flag for bulid-dependencies, then re-building the debian package will get you what you need?
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
