Re: [mpich-discuss] How to terminate MPI_Comm_accept
Hi Pavan, I tried doing dup on both sides as well as on the client side only. Both cases, it did not work. Thanks, Hirak Here is the server-side MPI_Comm dupCom ; MPI_Comm_dup (MPI_COMM_SELF, &dupCom); do { MPI_Comm newComm ; MPI_Comm_accept (m_serverPort.c_str(), MPI_INFO_NULL, 0, dupCom, &newComm); int buf = 0 ; MPI_Status status ; Log ("Waiting on receive"); MPI_Recv(&buf, 1, MPI_INT, MPI_ANY_SOURCE, MPI_ANY_TAG, newComm, &status); Log ("Receive complete"); if (status.MPI_TAG == MPI_MSG_TAG_NEW_CONN) { m_clientComs[m_clientCount] = newComm ; m_clientCount++; } else if (status.MPI_TAG == MPI_MSG_TAG_SHUTDOWN) { Log ("Shutdown"); MPI_Comm_disconnect (&newComm); Log ("Disconnect"); break; } else { Log ("Unmatched Receive"); } } while(1) ; Are you doing MPI_Comm_dup while the other thread is doing MPI_Comm_accept? - Pavan From: Roy, Hirak Sent: Thursday, October 09, 2014 12:55 AM To: [email protected] Subject: Re: Re: Re: How to terminate MPI_Comm_accept Hi Pavan, Does not work. Crash in nemesis. Sock hangs in MPI_Recv/MPI_Send Thanks, Hirak MPI_Comm newComm ; MPI_Comm dupCom ; MPI_Comm_dup (MPI_COMM_SELF, &dupCom); MPI_Comm_connect (m_serverPort.c_str(), MPI_INFO_NULL, 0, dupCom, &newComm); Log ("Connect to Self"); int val = 0 ; MPI_Request req ; MPI_Send(&val, 1, MPI_INT, 0, MPI_MSG_TAG_SHUTDOWN, newComm); Log ("Successful"); MPI_Comm_disconnect(&newComm); On Oct 8, 2014, at 11:41 AM, Roy, Hirak <Hirak_Roy at mentor.com<https://lists.mpich.org/mailman/listinfo/discuss>> wrote:
Is there any way to come out of the blocking accept?
You can dup MPI_COMM_SELF and do the connect using that other communicator. - Pavan -- _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Roy, Hirak
