Re: [mpich-discuss] couldn't built mpich-master on SuSE Linux with Sun C
Siegmar, In case you didn't see it, this is the PR: https://github.com/pmodels/mpich/pull/3353. Ken On 10/3/18 3:53 PM, Congiu, Giuseppe wrote:
Siegmar,
I have created a pull request that should fix the fortran detection problem with mpich. Can you try it and see if it works for you?
Thank you, Giuseppe
On Oct 3, 2018, at 1:25 PM, Congiu, Giuseppe <[email protected] <mailto:[email protected]>> wrote:
Hi Siegmar,
We have looked into the problem. It seems this is not MPICH specific but rather libtools specific. I have created an issue (https://github.com/pmodels/mpich/issues/3350) for this. You can look at it for bug fix updates.
Best, Giuseppe
On Oct 1, 2018, at 6:16 AM, Siegmar Gross <[email protected] <mailto:[email protected]>> wrote:
Hi Giuseppe,
my email is being held until the list moderator can review it for approval, because the attachments are too big. Therefore, I send it directly to you.
Best regards
Siegmar
-------- Forwarded Message -------- Subject: Re: [mpich-discuss] couldn't built mpich-master on SuSE Linux with Sun C Date: Mon, 1 Oct 2018 10:37:58 +0200 From: Siegmar Gross <[email protected] <mailto:[email protected]>> To: Users MPICH <[email protected] <mailto:[email protected]>>
Hi Giuseppe,
today I've tried to build the latest master version so that you don't have to deal with an old version. I still get the same error.
loki mpich-master_2018-10-01_Linux.x86_64.64_cc 150 cc -V cc: Studio 12.6 Sun C 5.15 Linux_i386 2017/05/30
I've attached the requested files. Thank you very much for any help in advance.
Best regards
Siegmar
On 09/26/18 21:41, Congiu, Giuseppe wrote:
Hi Siegmar, I have tried replicating the linking problem using the configure options you provided. I have used Oracle Developer Studio 12.3. Mpich master “701bc7e5f84467188dcdc1ff585349e994a9990a". Compilation worked fine for me. Can you attach your config.log file so I can have a look at it? Moreover, can you recompile Mpich with "make V=1" and attach the corresponding output as well? Thank you, Giuseppe
On Jun 6, 2018, at 6:21 AM, Siegmar Gross <[email protected] <mailto:[email protected]>> wrote:
I tried to build mpich-master on my "SUSE Linux Enterprise Server 12.3 (x86_64)" with Sun C 5.15 (Oracle Developer Studio 12.6). Unfortunately, I get the following error, that I already reported already on May 9th.
loki mpich-master_2018-06-06_Linux.x86_64.64_cc 122 tail -22 log.make.Linux.x86_64.64_cc | grep -v NOTICE "../mpich/src/include/mpir_handlemem.h", line 61: warning: null dimension: indirect "../mpich/src/include/mpir_handlemem.h", line 122: warning: null dimension: indirect MOD src/binding/fortran/use_mpi/mpi.mod-stamp "./src/include/mpichconf.h", line 1708: Warning (Anachronism): Attempt to redefine __restrict__ without using #undef. 1 Warning(s) detected. f90: Warning: Option -shared passed to ld, if ld is invoked, ignored otherwise f90: Warning: Option --whole-archive passed to ld, if ld is invoked, ignored otherwise f90: Warning: Option --no-whole-archive passed to ld, if ld is invoked, ignored otherwise f90: Warning: Option -path passed to ld, if ld is invoked, ignored otherwise f90: Warning: Option -path passed to ld, if ld is invoked, ignored otherwise f90: Warning: Option -soname passed to ld, if ld is invoked, ignored otherwise /usr/bin/ld: -r and -shared may not be used together postopt: error: ld failed to link the binary Makefile:16787: recipe for target 'lib/libmpi.la <http://libmpi.la/>' failed make[2]: *** [lib/libmpi.la <http://libmpi.la/>] Error 2 make[2]: Leaving directory '/export2/src/mpich-master/mpich-master_2018-06-06_Linux.x86_64.64_cc' Makefile:39797: recipe for target 'all-recursive' failed make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory '/export2/src/mpich-master/mpich-master_2018-06-06_Linux.x86_64.64_cc' Makefile:10453: recipe for target 'all' failed make: *** [all] Error 2 loki mpich-master_2018-06-06_Linux.x86_64.64_cc 123
I used the following commands to update and configure MPICH.
cd mpich git pull https://github.com/pmodels/mpich.git master git submodule update --init --recursive autogen.sh
mkdir mpich-master_`date -I'date'`_${SYSTEM_ENV}.${MACHINE_ENV}.64_cc cd mpich-master_`date -I'date'`_${SYSTEM_ENV}.${MACHINE_ENV}.64_cc
../mpich/configure \ --prefix=/usr/local/mpich-master_64_cc \ --libdir=/usr/local/mpich-master_64_cc/lib64 \ --includedir=/usr/local/mpich-master_64_cc/include64 \ CC="cc" CXX="CC" F77="f77" FC="f95" \ CFLAGS="-m64" CXXFLAGS="-m64" FFLAGS="-m64" FCFLAGS="-m64" \ LDFLAGS="-m64 -L/usr/lib64 -R/usr/lib64" \ --enable-fortran=yes --enable-cxx --enable-romio \ --enable-debuginfo --enable-smpcoll \ --enable-threads=multiple --with-thread-package=posix \ --enable-shared \ |& tee log.configure.$SYSTEM_ENV.$MACHINE_ENV.64_cc
make -j 6 |& tee log.make.$SYSTEM_ENV.$MACHINE_ENV.64_cc
I would be grateful, if somebody can fix the problem or is it a problem of the Oracle compiler?. Do you need anything else? Thank you very much for any help in advance.
Kind regards
Siegmar _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
<config.log><log.configure.Linux.x86_64.64_cc><log.make.Linux.x86_64.64_cc>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Raffenetti, Kenneth J.
