Re: [mpich-discuss] Debugging MPI Window
Hi Bruce, If you want to check if the window object is the same, you can compare the window handle value. Just note that if you do win_create-win_free-win_create, the second window may be assigned with the same handle as the first one. Best regards, Min On 2019/04/17 17:32, Palmer, Bruce J via discuss wrote: Hi, Strictly for debugging purposes, is there a way in MPICH to determine if a MPI_Win created at point A in a code is the same window being accessed at point B? It doesn’t need to be portable, I’m just interested in using it to fix some bugs (that are probably not associated with MPI). Bruce Palmer Computer Scientist Pacific Northwest National Laboratory (509) 375-3899 _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Si, Min
