Re: [mpich-discuss] Failed to allocate memory for an unexpected message
Thanks On 1 November 2013 22:00, Pavan Balaji <[email protected]> wrote:
On Nov 1, 2013, at 4:30 PM, Luiz Carlos da Costa Junior <[email protected]> wrote:
I understand that I will have to have N buffers, one for each posted MPI_Irecv. I will also have to TEST (using MPI_PROBE or MPI_WAITANY) until a message comes. The result of this test will identify which one of the posted MPI_Irecv has actually received the message and then process the right buffer. Is this correct?
Correct.
Should I have to change anything at the sender's processes?
Likely not. But you need to think through your algorithm to confirm that.
At the end, my receiver process receives a message identifying that it should exit this routine. What should I do with the already posted MPI_Irecv's? Can I cancel them?
Yes, you can with MPI_CANCEL.
—- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
