Re: [mpich-discuss] Internal Error: invalid error code 409e10 (Ring ids do not match)
You can try install MPICH on your user directory by: ./configure —prefix=/your/directory See http://www.mpich.org/static/downloads/3.1/mpich-3.1-installguide.pdf for more information. — Huiwei On Jun 2, 2014, at 5:18 PM, Jakub Łuczyński <[email protected]> wrote:
This are Linux platforms, and I do not have administrative rights to change anything in this environment (it is shared, multiuser env, with this version of MPICH installed for quite time i guess). I could try to talk with administrators but i am not 100% sure that the code (posted in this mail) is correct.
Best regards, Kuba
On Tue, Jun 3, 2014 at 12:03 AM, Lu, Huiwei <[email protected]> wrote: Hi Kuba,
Since it works with both Open MPI and BGP, it is most likely a problem of your MPICH installation or your platform.
We have stopped supporting the Windows platform a while ago due to lack of developer resources. Please refer to our FAQ for more information: http://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_Why_can....
If it is on windows platform, we recommend you use Microsoft MPI, which can be found here: http://msdn.microsoft.com/en-us/library/bb524831(v=vs.85).aspx
We also encourage you to use the latest MPICH on Linux or OSX platforms, which can be downloaded here: http://www.mpich.org/downloads/
— Huiwei
On Jun 2, 2014, at 4:49 PM, Jakub Łuczyński <[email protected]> wrote:
I wrote my assignment using MPI, and tested it both locally on Open MPI (1.6.5) and on IBM Blue Gene/P (with mpi implementation provided by IBM). Everything worked fine. Turns out that our solutions are tested also in our labs where MPICH, is installed:
$ mpich2version MPICH2 Version: 1.4.1p1
And when I run my solution there I get this strange error: $ mpirun -n 2 msp-par.exe 10 10 1 Internal Error: invalid error code 409e10 (Ring ids do not match) in MPIR_Reduce_impl:1087 Fatal error in PMPI_Reduce: Other MPI error, error stack: PMPI_Reduce(1270).....: MPI_Reduce(sbuf=0x7fff693a92e8, rbuf=0x7fff693a9300, count=1, dtype=USER<struct>, op=0x98000000, root=0, MPI_COMM_WORLD) failed MPIR_Reduce_impl(1087):
I am literally out of ideas what is wrong!
Below source code fragments (c++):
struct msp_solution { int x1, y1, x2, y2; m_entry_t max_sum; msp_solution(); msp_solution(const pair<int, int> &c1, const pair<int, int> &c2, int max_sum); friend bool operator<(const msp_solution &s1, const msp_solution &s2); };
void max_msp_solution(msp_solution *in, msp_solution *inout, int, MPI_Datatype*) { *inout = max(*in, *inout); }
// somewhere in code { MPI_Datatype MPI_msp_solution_t; MPI_Op max_msp_solution_op;
// create MPI struct from msp_solution MPI_Datatype types[] = { MPI_INT, MPI_LONG_LONG_INT }; int block_lengths[] = { 4, 2 }; MPI_Aint base_addr, x1_addr, max_sum_addr; MPI_Get_address(&collected_solution, &base_addr); MPI_Get_address(&collected_solution.x1, &x1_addr); MPI_Get_address(&collected_solution.max_sum, &max_sum_addr);
MPI_Aint displacements[] = { x1_addr - base_addr, max_sum_addr - base_addr };
MPI_Type_create_struct(2, block_lengths, displacements, types, &MPI_msp_solution_t); MPI_Type_commit(&MPI_msp_solution_t);
// max reduction function MPI_Op_create((MPI_User_function *) max_msp_solution, 1, &max_msp_solution_op);
msp_solution solution, received_solution; MPI_Comm comm, ... // comm is created using MPI_Comm_split // solution is initialized MPI_Reduce(&solution, &received_solution, 1, MPI_msp_solution_t, max_msp_solution_op , 0, MPI_COMM_WORLD); // ERROR above!!! }
Is there some error in this? How can I make it run? P.S. MPI_Send and MPI_Recv on my struct MPI_msp_solution_t seems to work fine
Thanks in advance! Best regards, Kuba _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lu, Huiwei
