Re: [mpich-discuss] MPI_File_open(...) - overwrite existing file
On 02/04/2016 11:01 AM, Thakur, Rajeev wrote:
It will not be truncated. If you need the file to be truncated, you will have to delete the file before opening.
this is a consistent theme in the standard. If you call MPI_FILE_SET_SIZE to shrink a file, it will also leave old data in an undefined state. ==rob
Rajeev
On Feb 4, 2016, at 10:37 AM, [email protected] wrote:
Dear MPI Group,
I'm wondering if the files created with the modes
MPI_MODE_CREATE | MPI_MODE_WRONLY
will be truncated to 0 if the file already exists calling MPI_File_open(...).
As far as I tested it and also which is written in the standard:
MPI_MODE_CREATE — create the file if it does not exist MPI_MODE_WRONLY — write only
The existing file will be overwritten, but leaving the bytes that have not been explicitly overwritten. Thus, an existing file with the size of 8 Bytes and data to be written to of 4 Bytes will still be 8 Bytes after writing: With the 4 Bytes of the new data and 4 Bytes of the old data.
As I read it, there is nothing defined what happens with the data of the file if it already exists [p 494, 1].
The POSIX / GNU lib c standard states that the file will be truncated to 0 if opened with 'w' and the file does already exists calling fopen(...) [p. 249, 2]:
‘w’ - Open the file for writing only. If the file already exists, it is truncated to zero length. Otherwise a new file is created.
I really would appreciate some input if I'm wrong or not and what to do if the file needs to be truncated before writing (other then deleting the file before).
Kind regards
Florian Willich
[1]: Message Passing Interface Forum. 2015. MPI: A Message-Passing Interface Standard Version 3.1. http://mpi-forum.org/docs/mpi-3.1/mpi31-report.pdf. [Online. Accessed 2nd December 2015].
[2]: Loosemore, Sandra, Stallman, Richard M., McGrath, Roland, Oram, Andrew, & Drepper, Ulrich. 2015. The GNU C Library Reference Manual. http://www.gnu.org/software/libc/manual/pdf/libc.pdf. [Online. Accessed 24th January 2016].
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR) German Aerospace Center Institute of Planetary Research | Planetary Physics | Rutherfordstraße 2 | 12489 Berlin
Florian Willich| Candidate for Bachelor of Science Software Developer (Parallel Applications) [email protected] DLR.de _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rob Latham
