Re: [mpich-discuss] Linking to personal libraries
static vs. dynamic linking has nothing to do with the NFS. With static linking, the executable needs to be available on all nodes (either through the NFS or through explicit copies). With dynamic linking, the executable and all its dependency libraries need to be available on all nodes (again, either through the NFS or through explicit copies). So far, mpich used static builds by default. All released versions so far use this model. You can ask it to build dynamic libraries as well by passing --enable-shared to configure. We recently moved to building mpich as a dynamic library by default as well (both static and dynamic libraries will be built, but the dynamic library is prioritized for linking). You'll see this model in the upcoming mpich-3.1.x series and beyond. -- Pavan On 06/07/2013 06:48 AM, Alejandro Allievi wrote:
Good morning Wesley,
Under NFS, is there a way to bypass dynamic linking and "force" static linking??
Thanks.
Alejandro
On Thu, Jun 6, 2013 at 3:52 PM, Alejandro Allievi <[email protected] <mailto:[email protected]>> wrote:
Thanks!!
On Thu, Jun 6, 2013 at 3:44 PM, Wesley Bland <[email protected] <mailto:[email protected]>> wrote:
No, this is the correct way to do it.
On Jun 6, 2013, at 11:12 AM, Alejandro Allievi <[email protected] <mailto:[email protected]>> wrote:
Is there a better way??
On Thu, Jun 6, 2013 at 3:40 PM, Wesley Bland <[email protected] <mailto:[email protected]>> wrote:
That's true and for most smallish clusters, that's how people use it.
On Jun 6, 2013, at 11:09 AM, Alejandro Allievi <[email protected] <mailto:[email protected]>> wrote:
Hi Wesley,
Just to clarify myself: provided our NFS mirrors my home directory and that LD_LIBRARY_PATH is set correctly, the dynamic compile/link step for the user (me) is the same as for static compile/link??
Thanks again Wesley!!
Alejandro
On Thu, Jun 6, 2013 at 11:15 AM, Wesley Bland <[email protected] <mailto:[email protected]>> wrote:
It depends on whether you are linking your library statically or dynamically. If you are linking statically, the linker puts everything in one executable that is sent to all of the nodes. If you do it dynamically, you need to make sure your libraries are available on all of the nodes you will be using (usually by using something like NFS to mirror your home directory across the cluster. You will also need to make sure your environment is set up correctly to allow the libraries to be found on the remote process, usually via an environment variable such as LD_LIBRARY_PATH.
Wesley
On Jun 6, 2013, at 6:18 AM, Alejandro Allievi <[email protected] <mailto:[email protected]>> wrote:
H i
When linking to personal libraries using MPICH2, how does each process access them in a distributed environment?? Does the linker actually combines everything into a single executable program and "sends a copy" of entire executable to each process even though not all processes may use the libraries?? Can somebody shed some light on the entire linking process??
Thanks for any help!!
Alejandro _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Alejandro Allievi http://www.ace-net.ca/wiki/Alejandro_Allievi "Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre v�ritable sentiment n'est pas celui dans lequel nous n'avons jamais vacill�; mais celui auquel nous sommes le plus habituellement revenus". Denis Diderot. Este e-mail esta consignado s�lo para el destinatario designado en el mismo y puede contener informaci�n confidencial y privilegiada. Su distribuci�n o copiado est� prohibido. Si Usted no fuera el destinatario designado, por favor notif�quenos de inmediato y destruya este e-mail en forma permanente as� como todas las copias del mismo. _Ce courriel peut renfermer des renseignements confidentiels et privil�gi�s et s'adresse au destinataire d�sign� seulement. La distribution ou la copie de ce courriel est interdit. Si vous n'�tes pas le destinataire d�sign�, veuillez nous en aviser imm�diatement et d�truire de fa�on permanente ce courriel ainsi que toute copie de celui-ci_. This e-mail may contain confidential information, and is intended only for the named recipient and may be privileged. Distribution or copying of this email is prohibited. If you are not the named recipient, please notify us immediately and permanently destroy this email and all copies of it. _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
