Re: [mpich-discuss] Is it okay to remove F77 support?
Everybody wishing to have a serious opinion on ISO Fortran 77 should read the following: https://stevelionel.com/drfortran/2020/05/16/doctor-fortran-in-military-stre... Also, Squyres is right about everything, as usual. Jeff On Wed, Jan 27, 2021 at 7:09 AM Jeff Squyres (jsquyres) via discuss < [email protected]> wrote:
On Jan 27, 2021, at 9:45 AM, Raffenetti, Kenneth J. via discuss < [email protected]> wrote:
The MPICH team is asking if it would be OK to drop support for building
MPICH with an F77 only compiler.
MPI -- MPICH, Open MPI, etc. -- has never been able to be built with a F77-only compiler because the MPI standard has never adhered to the Fortran 77 standard.
Additionally, MPI-3.1 17.1.1 quite clearly states that a conformant MPI-3.1 implementation must support either the mpi_f08 module (which implies support for much of the Fortran'08 standard) and/or mpif.h + the mpi module (which requires elements of the Fortran 90 standard). This requirement has been there since MPI-3.0, published in 2012.
Hence, it has not been possible to build any conformant MPI implementation with a "F77-only" compiler for nearly a decade.
And let's not forget that Fortran 77 limits symbols -- variables, subroutines, and functions -- to 6 characters. Hence, it has *never* been possible to build any MPI implementation or application with a Fortran 77-only compiler.
Håkon's answer earlier in the thread was also quite correct: "fixed form Fortran" is not the same thing as "Fortran 77". Please stop conflating the two.
MPICH will still support all standard Fortran language bindings: mpif.h, use mpi, and use mpi_f08. Does the code you speak of not build with modern Fortran compilers? If so, that is the kind of feedback we are looking for.
That is a good question, much better formed than the original. It's a question that the entire MPI Forum would benefit hearing answers to!
-- Jeff Squyres [email protected]
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
