mpi client/server : problem with mpich3
Hello, I am using MPI Client/Server features to couple 2 codes. You can find a short example in attached file. In the Makefile, mpif90 is the wrapper for mpich compiled with gfortran. With mpich2, I manage to run a client/server case without any problem with the following script : mpirun -np 1 ./Serveur > Serveur.log & sleep 5 mpirun -np 1 ./Client > gradym_client.log and I am able to run many coupled simulations on the same computer. With mpich3, the script above doesn't work any more. I have found another way to run my coupled case in the mpich3 manual : #/bin/csh set hydraPID=`ps -u $USER | grep hydra_nameserve | cut -d ' ' -f 1` kill -9 $hydraPID /PRODCOM/Ubuntu12.04/hydra/3.1.4/intel-15.0/bin/hydra_nameserver & mpiexec -hosts `hostname` -n 1 -nameserver `hostname` ./Serveur & sleep 1 mpiexec -hosts `hostname` -n 1 -nameserver `hostname` ./Client set hydraPID=`ps -u $USER | grep hydra_nameserve | cut -d ' ' -f 1` echo $hydraPID kill -9 $hydraPID It is more complicated and I can only run one simulation by computer at the same time because I can launch only one hydra server. Do you know another way to run client/server simulation with mpich3? What can I do to run many client server simulation on the same host? Thanks a lot for your help. A. Pedrono -- -------------------------------------------------------------------------- Annaig PEDRONO Institut de Mecanique des Fluides Tel : (33) (0)5 34 32 29 06 Allee du Professeur Camille SOULA Fax : (33) (0)5 34 32 28 99 31400 TOULOUSE, FRANCE e-mail :[email protected] --------------------------------------------------------------------------- _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
PEDRONO Annaig
