Re: [mpich-discuss] About mpi i/o, mpi hints and collective i/o memory usage
Hi Rob, Are you the same Pramod Kumbhar that works at EPFL? Yes. After seeing failure on 8-rack, I started debugging/profiling on our local 4-rack bg-q system. I planned to send an email to support team with more detailed information (for which job is currently in queue). 1: collective I/O does consume some memory. not only is there an
internal "collective buffer" maintained by MPI-IO itself, but the data exchange copies data as well before calling ALLTOALL.
Just wondering if there any way to print or query some internal statistics about this.
Paul Coffman has done a one-sided based two-phase implementation that should be lower memory overhead. But here we should take the discussion off-list.
Perfect ! Thanks! Regards, Pramod ==rob
Quick Summary :
1. On bg-q I see cb_buffer_size as 16MB when we query on file handle using MPI_File_get_info. An application that we are looking at has code section like:
…. MPI_File_set_view( fh, position_to_write, MPI_FLOAT, mappingType, _native_, MPI_INFO_NULL ); max_mb_on_any_rank_using_Kernel_GetMemorySize () => 275 MB MPI_File_write_all( fh, mappingBuffer, .................... MPI_FLOAT, &status); max_mb_on_any_rank_using_Kernel_GetMemorySize () => 373 MB ……
Why we see that spike in memory usage? (see Detail section for size information)
I have seen “Kernel_GetMemorySize(KERNEL_MEMSIZE_HEAP….)” not returning accurate memory footprint but I am not sure if that is the case here. Darshan screenshot attached shows the access sizes while running on 4 rack.
2. Is romio_cb_alltoall ignored on bg-q? Even if I disable it, I see “automatic” in the output.
(I am looking at srcV1R2M4/comm/lib/dev/mpich2/src/mpi/romio/adio/ad_bg/ad_bg_hints.c and see the code section is commented.)
More Details :
We are debugging an application on MIRA which runs on 1,2,4 racks but fails at 8 racks while dumping a custom checkpoint. These are strong scaling runs and the size of checkpoint remains same (~172GB). 32 ranks per mode. Max memory usage before start of checkpoint (i.e. before single write_all call) for 8 rack is ~ 300 MB. The checkpoint size from each rank is between Kbs to few MBs (as shown by darshan). Once application call checkpoint, we see below error :
Out of memory in file /bgsys/source/srcV1R2M2.15270/comm/lib/dev/mpich2/src/mpi/romio/adio/ ad_bg/ad_bg_wrcoll.c, line 500
And hence I am confused about behaviour mentioned in question 1. If someone has any insight, it will be great help!
Regards, Pramod
p.s.
Default values of all hints
cb_buffer_size, value = 16777216 romio_cb_read, value = enable romio_cb_write, value = enable cb_nodes, value = 8320 (change based on partition size) romio_no_indep_rw, value = false romio_cb_pfr, value = disable romio_cb_fr_types, value = aar romio_cb_fr_alignment, value = 1 romio_cb_ds_threshold, value = 0 romio_cb_alltoall, value = automatic ind_rd_buffer_size, value = 4194304 romio_ds_read, value = automatic romio_ds_write, value = disable _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
pramod kumbhar
