Re: [mpich-discuss] Issues installing MPICH on Ubuntu 14.04
It seems like the install went through fine, but when I check which mpicc and which mpiexec nothing happens. Do I need to use apt-get to get these going or did something else go wrong? Appreciate the help! On Thu, Oct 2, 2014 at 10:44 AM, mhgardner <[email protected]> wrote:
Great, thank you very much.
On Thu, Oct 2, 2014 at 10:38 AM, Wesley Bland <[email protected]> wrote:
From your config.log, it looks like you don’t have a Fortran compiler installed. If you don’t plan to use it, that’s fine, but you should pass —disable-fortran to the configure script.
Thanks, Wesley
On Oct 2, 2014, at 12:35 PM, mhgardner <[email protected]> wrote:
I'm trying to install MPICH in Ubuntu 14.04, but when I try to build it says no targets are specified. I'm following the install instructions from the following page: http://www.mpich.org/static/downloads/3.1.2/mpich-3.1.2-installguide.pdf The c.txt and m.txt files are attached. Not sure where things are going wrong, so any guidance would great.
Mike <c.txt><m.txt>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
mhgardner
