Re: [mpich-discuss] 'nonblocking' test needs revision
Thanks, patch applied. On 10/05/2016 08:18 AM, Jeff Hammond wrote:
Attached, pushed to mpich-review/fix-mpich-test-dt-types and pushed to https://github.com/jeffhammond/mpich/tree/fix-mpich-test-dt-types.
Jeff
On Wed, Oct 5, 2016 at 3:25 AM, Chris Ward <[email protected] <mailto:[email protected]>> wrote:
I'm using the MPICH BVT tests to test a build of OpenMPI. While doing that, I find that 'nonblocking.c' needs to be revised as follows // int *types = NULL; MPI_Datatype *types = NULL;
// types = malloc(size * sizeof(int)); types = malloc(size * sizeof(MPI_Datatype));
Presumably it works as-is for mpich because MPI_Datatype is an 'int'; but this isn't the case for other MPI implementations. Would one of the mpich developers care to make these changes to the source code ? *T J (Chris) Ward, IBM Research. Scalable Data-Centric Computing - Active Storage Fabrics - IBM System BlueGene IBM United Kingdom Ltd., Hursley Park, Winchester, Hants, SO21 2JN 011-44-1962-818679 LinkedIn **_https://www.linkedin.com/profile/view?id=60628729_* <https://www.linkedin.com/profile/view?id=60628729>* ResearchGate **_https://www.researchgate.net/profile/T_Ward2_* <https://www.researchgate.net/profile/T_Ward2>* **_ _**_IBM System BlueGene Research_* <http://www.research.ibm.com/bluegene/>***_ _**_IBM System BlueGene Marketing_* <http://www-03.ibm.com/systems/deepcomputing/bluegene/>* **_ _**_IBM Resources for Global Servants_* <http://hurgsa.ibm.com/~tjcw/Compete/>***_ _**_IBM Branded Products_* <http://www.ibm.com/shop>***_IBM Branded Swag_* <http://ibmlogogear.com/default.aspx>** <http://www.ibm.com/developerworks/linux/library/l-bluegene/index.html>
UNIX in the Cloud - Find A Place Where There's Room To Grow, with the original Open Standard. _Free Trial Here Today_ <http://sdf.lonestar.org/index.cgi?telnet> New Lamps For Old - _Diskless Remote Boot Linux_ <http://drbl.sourceforge.net/>from _National Center for High-Performance Computing, Taiwan_ <http://www.nchc.org.tw/en/>
Unless stated otherwise above: IBM United Kingdom Limited - Registered in England and Wales with number 741598. Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6 3AU
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
