Re: [mpich-discuss] configuration issues: complex.h and CROSS_F77_SIZEOF_INTEGER
If you don't need to use Fortran, you can configure with --disable-fortran. Rajeev On Apr 8, 2015, at 10:36 PM, Lou Picciano <[email protected]> wrote:
Attempting to configure mpich-3.2b1 for the SolarisStudio12.4 suite...
Issues around complex.h (Yes, I'll have to look for prerequisites)
and the message about FORTRAN integer length - which seems to have been dealt with a couple of years ago, and only in the ifort context?
CROSS_F77_SIZEOF_INTEGER seems to be ignored; I've tried all of 1,2,4,8...
Many thanks!
checking complex.h presence... yes configure: WARNING: complex.h: present but cannot be compiled configure: WARNING: complex.h: check for missing prerequisite headers? configure: WARNING: complex.h: see the Autoconf documentation configure: WARNING: complex.h: section "Present But Cannot Be Compiled" configure: WARNING: complex.h: proceeding with the compiler's result configure: WARNING: ## -------------------------------- ## configure: WARNING: ## Report this to [email protected] ## configure: WARNING: ## -------------------------------- ## checking for complex.h... no checking size of _Bool... 0 checking size of float _Complex... 0 checking size of double _Complex... 0 checking size of long double _Complex... 0 checking for _Bool... no checking for float _Complex... no checking for double _Complex... no checking for long double _Complex... no checking for size of Fortran type integer... 0 checking for size of Fortran type real... 0 checking for size of Fortran type double precision... 0 checking whether integer*1 is supported... yes checking whether integer*2 is supported... yes checking whether integer*4 is supported... yes checking whether integer*8 is supported... yes checking whether integer*16 is supported... no checking whether real*4 is supported... yes checking whether real*8 is supported... yes checking whether real*16 is supported... yes configure: error: Unable to configure with Fortran support because configure could not determine the size of a Fortran INTEGER. Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes of a Fortran INTEGER _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Thakur, Rajeev
