Re: [mpich-discuss] MPICH Test Suite - limit number of processes
Unfortunately, the number of processes for each test is hardcoded in the testlist files. There is no mechanism for filtering or dynamically modifying them. You could either maintain a custom patch to modify the testlist, or have a script applying a separate xfail list. An example of such xfail list that we used in our internal testing is in test/mpi/maint/jenkins/xfail.conf. If the custom patch solution won't work in your situation, please open an github issue describing your use case, and we can discuss to add a filtering option to the runtests script. -- Hui ________________________________ From: Max R. Dechantsreiter via discuss <[email protected]> Sent: Thursday, January 12, 2023 9:58 AM To: [email protected] <[email protected]> Cc: Max R. Dechantsreiter <[email protected]> Subject: [mpich-discuss] MPICH Test Suite - limit number of processes I would like to limit the number of processes used by the MPICH Test Suite, which I run by "make testing" after building MPICH. I tried export MPITEST_PPNMAX=<n> # The maximum number of processes per node. but this had no apparent effect: some tests still ran using more than 4 processes, when I replaced <n> by 4. How could I restrict these tests to run with maximum 4 processes, for example? _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Zhou, Hui
