Re: [mpich-discuss] Segmentation fault (signal 11) and Exit code 139
You compiled with Intel Fortran? That compiler puts static arrays on the stack, unlike GNU Fortran, which puts them on the heap. You can either use ulimit to make the stack huge or you can look up the compiler option for Intel that puts these arrays on the heap. Only ancient, poorly designed Fortran 77 codes have this problem, by the way. Jeff On Tue, Jul 9, 2013 at 8:49 PM, Zheng Li <[email protected]> wrote:
ulimit -s 262140 By setting the stack size to 256M, this issue was solved.
Lee
2013/7/9 Jeff Hammond <[email protected]>
Not an MPICH problem. Contact WRF support.
Jeff
Sent from my iPhone
On Jul 9, 2013, at 2:09 AM, Zheng Li <[email protected]> wrote:
Dear All,
I tried to run the default January 2000 Case (the East Coast Winter Storm of January 24-25, 2000) in WRF v3.5, and failed when running wrf.exe. The error is as follows:
[sl@sl0 em_real]$ mpirun -np 4 ./wrf.exe starting wrf task 0 of 4 starting wrf task 1 of 4 starting wrf task 2 of 4 starting wrf task 3 of 4
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = EXIT CODE: 139 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=================================================================================== YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11) This typically refers to a problem with your application. Please see the FAQ page for debugging suggestions
Does someone have idea of resolving this issue? Thanks in advance.
Lee
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dr. Zheng Li Research Assistant State Key Laboratory of Environmental Aquatic Chemistry Research Center for Eco-Environmental Sciences Chinese Academy of Sciences P. O. Box 2871, Beijing, 100085 China [email protected] _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
