Re: [mpich-discuss] weird behavior with mpiexe (3.0.4)
2013/5/29 Jeff Hammond <[email protected]>
Wouldn't a message such as "`pwd` directory does not exist on node
velascoj"
be more illustrative?
Yes. However, the set of improper uses of MPI that could generate helpful error messages is uncountable. Do you not think it is a good use of finite developer effort to implement an infinitesimal fraction of such warnings? There has to be a minimum requirement placed upon the user. I personally think that it should include running in a directory that actually exists.
Certainly! But then again, some developer must have thought it a good idea, since under different circumstances, I get: /bin/bash -c mpiexec -n 1 -hosts tauro,velascoj gmandel [proxy:0:0@tauro] launch_procs (./pm/pmiserv/pmip_cb.c:648): unable to change wdir to /tmp/edscott/mnt/tauro-home/GIT/gmandel (No such file or directory) [proxy:0:0@tauro] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:893): launch_procs returned error [proxy:0:0@tauro] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [proxy:0:0@tauro] main (./pm/pmiserv/pmip.c:206): demux engine error waiting for event [mpiexec@velascoj] control_cb (./pm/pmiserv/pmiserv_cb.c:202): assert (!closed) failed [mpiexec@velascoj] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [mpiexec@velascoj] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:197): error waiting for event [mpiexec@velascoj] main (./ui/mpich/mpiexec.c:331): process manager error waiting for completion Which is inconsistent with the previous behavior. Anyways, its no big deal. BTW, would you happen to know why a process which is started with MPI_Comm_spawn will go into what seems like an active wait after MPI_Comm_disconnect and MPI_Finalize has been called? These spawned processed will hog up CPU until the parent process exits. Curious enough, this behavior is not mirrored in openmpi. Edscott ------------------------------- Dr. Edscott Wilson Garcia Applied Mathematics and Computing Mexican Petroleum Institute
participants (1)
Edscott Wilson
