Re: [mpich-discuss] mpifort wrapper compiler?
On Fri, Dec 6, 2013 at 8:31 AM, Jeff Squyres (jsquyres) <[email protected]> wrote:
On Dec 6, 2013, at 9:16 AM, Jeff Hammond <[email protected]> wrote:
integer JeffSquyresIsUnfortunatelyRightSometimes
LOL!
The IBM XLF compiler can compile any valid Fortran code by specifying the language requested explicitly with a flag. I suppose I can just do the following:
alias mpif77='mpifort -gimme-f77' alias mpif90='mpifort -gimme-f90' alias mpif95='mpifort -gimme-f95' alias mpif03='mpifort -gimme-f03' alias mpif08='mpifort -gimme-f08'
I just find this annoying since it adds a previously unnecessary step to users' workflow and breaks backwards compatibility for anyone that relies upon their MPI implementation to provide mpif77.
A fair point.
Heh, but you could look at this as your MPI implementation gently prodding you to stop using ancient Fortran dialects. ;-) (yes, I know, I know... it's just a joke)
However, keep in mind that OMPI (and MPICH) only have mpif77 and mpif90 -- not mpif95, mpif03, or mpif08.
Just to be clear: are you saying that, for example, on IBM platforms, MPICH's mpif77 and mpif90 enforce F77 and F90 language compliance?
On Blue Gene: #!/bin/bash echo "mpixlf77 points to bgxlf, which assumes fixed source form and thus will not compile Fortran 90+ programs i.e. free source form." for n in 90 95 2003 2008; do echo "mpixlf$n points bgxlf$n, which assumes free source form and will likely fail to compile syntax incompatible with Fortran $n" done By default, XLF does not enforce strict language compliance, but it will enforce a wide range of syntax requirements that cause user codes to fail to compile. I recall more than one case where Fortran 2003 and 2008 differ just slightly and users have to use the compiler associated with precisely the language that they are trying to use. The free/fixed and comment syntax issues are by far the biggest problem, but they are not the only ones. Jeff -- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
