Re: [mpich-discuss] Mpich over RDMA sample
Niyaz, ofi_rxm:verbs is the correct provider. The ofi_rxm provides the verbs provider additional messaging semantics that are needed to be used in MPI. -- Hui Zhou From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 2:54 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Thank you for the reply. I did that; however, it selects ofi_rxm: verbs libfabric: 412098: 1718221892: : ofi_rxm: av: ofi_av_insert_addr(): 313<info> fi_addr: 1 libfabric: 412099: 1718221892: : ofi_rxm: av: ofi_av_insert_addr(): 313<info> fi_addr: ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Thank you for the reply. I did that; however, it selects ofi_rxm:verbs libfabric:412098:1718221892::ofi_rxm:av:ofi_av_insert_addr():313<info> fi_addr: 1 libfabric:412099:1718221892::ofi_rxm:av:ofi_av_insert_addr():313<info> fi_addr: 1 options: backend: cpu iters: 16 warmup_iters: 16 cache: 1 min_elem_count: 1 max_elem_count: 1 elem_counts: [1] validate: last window_size: 64 #------------------------------------------------------------ # Benchmarking: Bandwidth # #processes: 2 #------------------------------------------------------------ #bytes #repetitions Mbytes/sec 4 16 0.02 # All done libfabric:412098:1718221892::ofi_rxm:ep_ctrl:rxm_stop_listen():864<info> stopping CM thread libfabric:412099:1718221892::ofi_rxm:ep_ctrl:rxm_stop_listen():864<info> stopping CM thread As per https://urldefense.us/v3/__https://www.intel.com/content/www/us/en/docs/mpi-... <https://urldefense.us/v3/__https:/www.intel.com/content/www/us/en/docs/mpi-library/developer-guide-linux/2021-6/ofi-providers-support.html__;!!G_uCfscf7eWS!YajPk9G-sPCEDt44nrZQrYG8r7V_s953AsKjQ4w_vW5OzcjJXfdGHOINW-PEYIw-IcISZSCw1xIsIoJ-dbE$> , we need to add FI_PROVIDER=^ofi_rxm , but if do that, it moves back to sockets provider. Is here a way to combine ^ofi_rxm and verbs From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 2:41 PM To: Niyaz Murshed <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample Niyaz, All you need to do is to set an environment variable `FI_PROVIDER=verbs`. -- Hui Zhou From: Niyaz Murshed <[email protected]> Date: Wednesday, June 12, 2024 at 1:23 PM To: Zhou, Hui <[email protected]>, [email protected] <[email protected]> Cc: nd <[email protected]> Subject: Re: Mpich over RDMA sample When testing with Libfabric, verbs provider is selected. I did have to use “-e msg -d mlx5_1” so that it selects verbs. I was checking if there is anything like that for mpich sample tests. Else might need to do some hack in the code to force ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd When testing with Libfabric, verbs provider is selected. I did have to use “-e msg -d mlx5_1” so that it selects verbs. I was checking if there is anything like that for mpich sample tests. Else might need to do some hack in the code to force the selection of verbs. From: Zhou, Hui <[email protected]> Date: Wednesday, June 12, 2024 at 1:15 PM To: [email protected] <[email protected]> Cc: Niyaz Murshed <[email protected]>, nd <[email protected]> Subject: Re: Mpich over RDMA sample Libfabric support multiple providers. Sounds like it was selecting the sockets or tcp provider rather than a provider that support RoCE. I am not exactly sure whether the verbs provider will do that. If you can confirm the provider using libfabric tests, then you can try forcing MPICH to use that provider by setting the FI_PROVIDER environment variable. -- Hui Zhou From: Niyaz Murshed via discuss <[email protected]> Date: Wednesday, June 12, 2024 at 9:03 AM To: [email protected] <[email protected]> Cc: Niyaz Murshed <[email protected]>, nd <[email protected]> Subject: [mpich-discuss] Mpich over RDMA sample Hello, I am trying to learn about MPICH and its performance over RDMA. I am using libfabric and installed mpich using the below configure. ./configure --prefix=/opt/mpich/ --with-ofi=/opt/libfabric/ When I run any applications between 2 directly ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hello, I am trying to learn about MPICH and its performance over RDMA. I am using libfabric and installed mpich using the below configure. ./configure --prefix=/opt/mpich/ --with-ofi=/opt/libfabric/ When I run any applications between 2 directly connected servers having Mellanox NICs, I see that communication is happening over tcp and not over RoCE. Is there any way to test commination over RoCE ? For eg. I was able to test it for libfabric using the below sample that comes along with libfabric to test RMA. Is there something similar for MPICH ? or use the current sample to use RoCE by some parameter? Server : fi_rma_bw -s 192.168.1.100 -e msg -d mlx5_1 -S 1024 -I 1 Client : fi_rma_bw -s 192.168.1.200 -e msg -d mlx5_3 192.168.1.100 -S 1024 -I 1 Regards, Niyaz
participants (1)
Zhou, Hui
