Re: [mpich-discuss] MPICH-3.0.4 on Ubuntu
This is correct path of my mpich installation dir. So, I don't know, how to install mpich 3.0.4 on Ubuntu. Guide don't help me. I'm shoked)) I try to use MPICH on Windows last 2 months, and in the result I decided use Ubuntu. There are problems. It is very sorrow. You said, that easier way - using the pre-built packages, but I find 1.4.1 version. Is it stable version? May I get help with this version on this discuss forum? And, what about package manager? What is it? How I can use it? 2014/1/6 Wesley Bland <[email protected]>
You need to change '/home/you/mpich-install/bin' to the path of your mpich installation that you used in earlier steps.
The easier way to install on MPICH is to use the built in package manager or one of the pre-built packages available on the MPICH Downloads page.
Thanks, Wesley
On Jan 5, 2014, at 11:51 AM, Ярослав Иванов <[email protected]> wrote:
Hello, Pavan. But I see error on 6 step. 7 step don't return any error, but I have trouble with 8 step. setenv PATH /home/you/mpich-install/bin:$PATH export PATH=/home/you/mpich-install/bin:$PATH don't work.
and
which mpicc which mpiexec
don't work
maybe is there guide for Ubuntu installing?
2014/1/6 Pavan Balaji <[email protected]>
Hello,
Your m.txt file does not seem to indicate any such error.
-- Pavan
On Jan 5, 2014, at 11:13 AM, Ярослав Иванов <[email protected]> wrote:
Hello!
I want to install MPICH-3.0.4 on my virtual ubuntu machine, but I got some errors.
Install Guide: step 6
http://www.mpich.org/static/downloads/3.0.4/mpich-3.0.4-installguide.pdf
When I try: "make |& tee m.txt" It return error in param_vals.c no such file
So, I remake it with option VERBOSE=1. There are c and m txt files. <c.txt><m.txt>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
-- С уважением, Иванов Ярослав _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Ярослав Иванов
