Re: [mpich-discuss] Question about non-blocking MPI - 3
Hi Viet, If MPICH_ASYNC_PROGRESS=1 is necessary for your application to terminate, i.e., you see a deadlock without this flag, the applications has a correctness/portability issue. This env variable should only have a possible impact to performance (better compute/communication overlap) but should not be necessary to avoid deadlock. You can compare this to the classical send-send deadlock (example 3.9 in the standard), where the application relies on buffering / eager communication, but all send suddenly block. The portable fix for the application is not to increase the eager-limit, but to fix the communication pattern. Best Joachim Am 07.01.21 um 13:08 schrieb viet via discuss:
Dear Hui Zhou,
Thank you for your response to this thread. Could you give me some references on this issue?
It seems that the below environment setting is necessary.
Thank you for anything you can provide. Best, Viet.
On Tue, Jan 5, 2021 at 5:59 AM Zhou, Hui <[email protected]> wrote:
You don’t need any special settings to use non-blocking MPI collectives in MPICH.
-- Hui Zhou
*From: *viet via discuss <[email protected]> *Date: *Friday, December 4, 2020 at 7:12 AM *To: *[email protected] <[email protected]> *Cc: *[email protected] <[email protected]> *Subject: *[mpich-discuss] Question about non-blocking MPI - 3
Hello everyone,
What is the environment setting for the use of non-blocking MPI-3 * collectives in mpich3.3?
In Intel MPI, the setting is as follows
$ export I_MPI_ASYNC_PROGRESS=1 $ export I_MPI_ASYNC_PROGRESS_PIN=<CPU list>
Is there an equivalent setting in mpich3.3? Thank you, Viet.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dipl.-Inf. Joachim Protze IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Protze
