Re: [mpich-discuss] Error Running MPICH for Photochemical Modeling
Hi Abhishek: We had a similar issue and was fixed when the following were set as root by our sys admin. # NOTE: "Unlimited" is not truly unlimited. It # will set the given limit to the maximum value # determined by your hardware configuration ulimit -t unlimited # cputime ulimit -f unlimited # filesize ulimit -d unlimited # datasize ulimit -s unlimited # stacksize ulimit -c unlimited # coredumpsize ulimit -m unlimited # memoryuse ulimit -v unlimited # vmemoryuse ulimit -n unlimited # descriptors ulimit -l unlimited # memorylocked ulimit -u unlimited # maxproc Hope this helps, Sarika On Wed, Sep 17, 2014 at 11:04 AM, Balaji, Pavan <[email protected]> wrote:
On Sep 17, 2014, at 1:00 PM, Abhishek Bhat <[email protected]> wrote:
The application works when there is a less resource intensive runs (larger grid with larger grid spacing). The issue occurs when we have nested grid runs. Also the application works without any issues for less than 7 processes (1 I/O and 6 nodes).
That’s not an indication that the application is correct with more processes. Many applications work at smaller scales but fail at larger scals. From the error, the indications point to the application. I’d recommend digging into the application and figuring out what’s breaking. The -print-all-exitcodes that Sangmin suggested, or attaching a debugger might be useful for this.
— Pavan
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Sarika K
