Re: [mpich-discuss] Optimizing runtime for 4 mpiexec.hydra jobs
Hi Hui, Here is the updated list with your request: 1. One mpi job with mpiexec.hydra -n 64 myprog => 57.32s 2. One mpi job with mpiexec.hydra -bind-to numa -n 64 myprog => 50.52s 3. Two mpi jobs with mpiexec.hydra -n 64 myprog => 99.77s 4. Two mpi jobs with mpiexec.hydra -bind-to numa -n 64 myprog => 72.23s 5. Four mpi jobs with mpiexec.hydra -bind-to numa -n 64 myprog => 159.2s 6. Four mpi jobs with mpiexec.hydra -n 64 myprog => 159.9s Case 6 is the same speed as Case 5. The code is a CFD code based on a subdomain approach. There is communication between neighboring subdomains. The machine is a supermicro server with 512GB of memory. These small test cases use about 3% of the available memory. I want to run 4 larger MPI jobs concurrently. ________________________________ From: Zhou, Hui <[email protected]> Sent: Wednesday, November 13, 2019 8:55 AM To: [email protected] Cc: Douglas Dommermuth Subject: Re: [mpich-discuss] Optimizing runtime for 4 mpiexec.hydra jobs Hi Doug, What is your number running 4 mpi jobs without -bind-to numa? - Hui Zhou On Nov 13, 2019, at 10:39 AM, Douglas Dommermuth via discuss <[email protected]<mailto:[email protected]>> wrote: I am running Ubuntu 18.04.3 with MPICH 3.3~a2-4 and GFortran 4:7.4.0-1ubuntu2.3 and GCC 4:7.4.0-1ubuntu2.3CC on dual AMD EPYC 7742 processors with hyper threading enabled. My codes are written in MPI and Fortran. The dual AMD processors have 128 cores and 256 threads. I want to optimize the runtime for 4 mpi jobs running concurrently with 64 threads each. Some timings are provided here: 1. One mpi job with mpiexec.hydra -n 64 myprog => 57.32s 2. One mpi job with mpiexec.hydra -bind-to numa -n 64 => 50.52s 3. Two mpi jobs with mpiexec.hydra -n 64 myprog => 99.77s 4. Two mpi jobs with mpiexec.hydra -bind-to numa -n 64 => 72.23s 5. Four mpi jobs with mpiexec.hydra -bind-to numa -n 64 => 159.2s The option "-bind-to numa" helps, but even so, running four mpi jobs concurrently with 64 threads each is considerably slower than running one mpi job with 64 threads. I can almost run four mpi jobs sequentially and match the time for running four mpi jobs concurrently. How can I improve on the result for running 4 mpi jobs concurrently? Thanks, Doug. _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Douglas Dommermuth
