Re: [mpich-discuss] MPI_Send over ibverbs
Hi, none of the MPI send calls has a requirement to return after the message was received. MPI_Send can return as soon as the caller can write to buffer without impact to the data being transferred. This might be after the data is put to the network, or the MPI library copied the data to an internal buffer. MPI_Ssend has the requirement to return after the message was matched at the receiver, which implies that the matching Receive was called. But it still does not require that the message was received at this point. Best Joachim Am 08.10.24 um 04:55 schrieb Niyaz Murshed via discuss:
Is there a way to check the implementation of MPI_Send?
As I understand there is an implicit barrier which allows MPI_Send to return only after the buffer is received by the destination.
How is this communication done? How does the destination notify the sender that buffer is received?
How is this implemented when using rocev2 ?
Niyaz
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dr. rer. nat. Joachim Jenke IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Jenke
