Re: [mpich-discuss] reading from a read only directory
On Tue, Dec 3, 2013 at 8:20 AM, Rob Latham <[email protected]> wrote:
On Sat, Nov 30, 2013 at 08:35:39AM -0600, Jed Brown wrote:
Geoffrey Irving <[email protected]> writes:
It's not an issue for me personally anymore: chmod +w . is fine, and symlinks would also solve the problem. The question was more about the motivation for the code and whether it's an issue anything thinks is worth fixing (or fixable at all). That and Jed asked me several times to start the thread. :)
It's not intuitive and does not appear to be documented. Reading from a read-only directory is a reasonable thing to try and people should not have to wait through a queue to find out that it doesn't work.
Mea culpa. MPI_File_read_ordered is implemented in "stupid mode" right now, and no one ever complained -- we don't pay much attention to shared file pointers. Tell me more about how you are relying on ordered mode, please.
I'm dividing a large file into nearly equal size chunks and slurping the entire file into RAM. Then I do a bunch of rearrangement in memory. I could just as easily use MPI_File_read_at_all, but had assumed that ordered was better because my known intervals happen to be ordered and contiguous. Should I be using MPI_File_read_at_all instead, and treating the ordered routine as vestigial?
The technical issues here: the shared file pointer and ordered mode collectives keep as global state the location of the shared file pointer. Where does it keep this state? Why, in the file system of course. Because using a file system as a message-passing medium is exactly what file systems are good at.... uh, well, maybe not, but it's the most portable option.
You can also do this with RMA windows (Rob Ross and I published some papers on this topic back in 05 and 06). Has a few drawbacks but it's got to be better than the file system.
Even without the RMA windows, we can still do a better job for ordered mode with MPI_SCAN -- it's just we need some globally-available place to get the old shared file pointer value and stash the new one.
In user-space, you'll outperform MPI-IO implementations if you manage the offset yourself.
Okay, I was basically assuming that if I used a collective routine, it would be smart about accessing the file system as few times as possible. If this isn't true I should unqueue my job now and switch to MPI_File_read_at_all. Is this right? Should I also use MPI_File_write_at_all instead of the shared fp collective write routine?
I wrote a little ordered mode shim you can link into your program. Looks like I last seriously did anything with it back in 2008 ? I cleaned up some of the warnings and made it use MPI_Count (remove HAVE_MPI_TYPE_SIZE_X from the makefile if you're on an old system). Caveat: I think the last time I ran this code was on Argonne's Blue Gene /L. Bear in mind the adage about tested code and broken code.
Thanks, though in my case switching away from the shared file pointer routine is easy, so I don't need the shim. Geoffrey
participants (1)
Geoffrey Irving
