Re: [mpich-discuss] Problem with SystemStubs under Mac OS X 10.7.5.
Hello Dave, ifort was installed after the upgrade to 10.7. Here is the output that you requested: [dgd]% mpif90 -show pi3f90.f90 /opt/intel/Compiler/11.0/059/bin/intel64/ifort pi3f90.f90 -I/usr/local/include -I/usr/local/include -L/usr/local/lib -lmpichf90 -lmpichf90 -lpmpich -lmpich [dgd]% mpif90 -v pi3f90.f90 mpif90 for 1.0.8p1 Version 11.0 /opt/intel/Compiler/11.0/059/bin/intel64/fortcom -D__INTEL_COMPILER=1100 -D_MT -D__INTEL_COMPILER_BUILD_DATE=20090131 -D__PIC__ -D__pic__ -D__APPLE__ -D__MACH__ -D__x86_64 -D__x86_64__ -mGLOB_pack_sort_init_list -I. -I/usr/local/include -I/usr/local/include -I/opt/intel/Compiler/11.0/059/include/intel64 -I/opt/intel/Compiler/11.0/059/include -I/usr/local/include -I/usr/include -O2 -mP1OPT_version=1100 -mGLOB_diag_file=/var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortK2SDC0.diag -mGLOB_diag_use_message_catalog=FALSE -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 -mGLOB_tune_for_fort -mGLOB_use_fort_dope_vector -mP2OPT_static_promotion -mP1OPT_print_version=FALSE -mP3OPT_use_mspp_call_convention -mCG_use_gas_got_workaround=F -mP2OPT_align_option_used=TRUE "-mGLOB_options_string=-I/usr/local/include -I/usr/local/include -v -L/usr/local/lib -lmpichf90 -lmpichf90 -lpmpich -lmpich" -mGLOB_position_independent_code -mGLOB_preemption_model=1 -mGLOB_cxx_limited_range=FALSE -mP2OPT_eh_nirvana -mGLOB_as_output_backup_file_name=/var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortfAUyYsas_.s -mIPOPT_activate -mIPOPT_lite -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 -mGLOB_extended_instructions=0x80 -mGLOB_advanced_optim=TRUE -mP2OPT_subs_out_of_bound=FALSE -mGLOB_ansi_alias -mIPOPT_args_in_regs=0 -mPGOPTI_value_profile_use=T -mP2OPT_hlo_level=2 -mP2OPT_hlo -mPAROPT_par_report=1 -mIPOPT_obj_output_file_name=/var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortK2SDC0.o -mGLOB_os_target=GLOB_OS_TARGET_MACH -mGLOB_obj_output_file=/var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortK2SDC0.o -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN -mP1OPT_source_file_name=pi3f90.f90 pi3f90.f90 ld -lcrt1.10.5.o -dynamic -arch x86_64 -weak_reference_mismatches non-weak -o a.out /opt/intel/Compiler/11.0/059/lib/for_main.o /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortK2SDC0.o -L/usr/local/lib -lmpichf90 -lmpichf90 -lpmpich -lmpich -L/opt/intel/Compiler/11.0/059/lib -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ -L/usr/lib/gcc/i686-apple-darwin11/4.2.1/x86_64/ -L/usr/lib/i686-apple-darwin11/4.2.1/ -L/usr/lib/ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/x86_64 -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/ -L/usr/lib/gcc/i686-apple-darwin11/4.2.1/x86_64 -L/usr/lib/gcc/i686-apple-darwin11/4.2.1/ -L/usr/llvm-gcc-4.2/bin/../lib/gcc/i686-apple-darwin11/4.2.1/../../../ /opt/intel/Compiler/11.0/059/lib/libifport.a /opt/intel/Compiler/11.0/059/lib/libifcore.a /opt/intel/Compiler/11.0/059/lib/libimf.a /opt/intel/Compiler/11.0/059/lib/libsvml.a /opt/intel/Compiler/11.0/059/lib/libipgo.a -lgcc -lgcc_s.10.5 -lgcc -lSystemStubs -lmx -lSystem /opt/intel/Compiler/11.0/059/lib/libirc.a -lpthread /opt/intel/Compiler/11.0/059/lib/libirc_s.a -ldl ld: library not found for -lSystemStubs rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifort0dZe82sw_vers rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortTuSifnlibgcc rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortbjjEHSgnudirs rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortbRSAZfdashv rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortvkktfoos rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortKKRMkztos rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortfAUyYsas_.s rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortRu8NBdarg rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//iforthbU583gnudirs rm /var/folders/dg/8sf80tms373_179jg3_sjb700000gn/T//ifortK2SDC0.o Thank you, Doug. On Feb 23, 2013, at 10:13 AM, Dave Goodell wrote:
On Feb 23, 2013, at 11:52 AM CST, Douglas Dommermuth wrote:
I have attached the files that you requested (files.tar.gz). I could not find this file: mpich-3.0.2/src/pm/hydra/tools/topo/hwloc/hwloc/config.log. The output for compling pi3f90.f90 is below:
mpif90 pi3f90.f90 ld: library not found for -lSystemStubs
Did you upgrade to 10.7 (Lion) without reinstalling the Intel Fortran compiler? Most of the google hits I'm getting about this indicate that it can happen when:
1) you have an ifort version <12.1; or
2) you installed ifort, then upgraded from 10.6 (or earlier) to 10.7 (or later).
Obviously, #1 does not appear to apply to you. So maybe #2 does?
We do have some logic to add "-lSystemStubs" to the link line in certain circumstances, but your config.log file is showing that we are not doing that in your case:
----8<---- pac_cv_prog_f77_and_c_stdio_libs=none […] pac_cv_prog_fc_and_c_stdio_libs=none ----8<----
Further debug might be accomplished by inspecting the output of these two commands:
----8<---- mpif90 -show pi3f90.f90 mpif90 -v pi3f90.f90 ----8<----
The first will show the ifort command that MPICH intends to execute. The second will show the commands that the ifort compiler driver executes as it attempts to compile your program. This should show us which part of the stack is incorrectly adding "-lSystemStubs" to your link line. My guess is that it's your ifort install, based on the other information that you have sent so far.
-Dave
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Douglas Dommermuth
