Re: [mpich-discuss] MPI_FILE_read and derived types in fortran.
Use MPI_Type_create_struct instead of MPI_Type_struct, which has been deprecated since 1997 and removed in MPI-3 in 2012 because of Fortran binding issues. For MPI_Type_create_struct, the offsets array needs to be declared as integer (kind=MPI_ADDRESS_KIND). See if that helps. Rajeev On Mar 11, 2014, at 11:25 AM, Scot Breitenfeld <[email protected]> wrote:
I created a file in fortran using (which I compiled with mpif90):
PROGRAM writeUstream
IMPLICIT NONE INTEGER :: i, ii INTEGER, DIMENSION(1:3,1:25) :: buf
OPEN(UNIT=11, FILE="ustream.demo", FORM="unformatted", STATUS="UNKNOWN", ACCESS="STREAM")
ii = 1
DO i=1, 25 buf(1,i) = ii buf(2,i) = ii+1 buf(3,i) = ii+2 WRITE(11) buf(1:3,i) ii = ii + 3 ENDDO CLOSE(UNIT=11)
END PROGRAM writeUstream
And I’ve made a simple program to read the file (on the same machine) using MPI_FILE_read:
PROGRAM struct
USE mpi
IMPLICIT NONE
INTEGER, PARAMETER :: NELEM = 2 INTEGER :: numtasks, rank, source, dest, tag, i, ierr INTEGER :: stat(MPI_STATUS_SIZE) INTEGER :: fh INTEGER :: status INTEGER(kind=MPI_OFFSET_KIND) :: disp
INTEGER, DIMENSION(1:3) :: iiaux
TYPE Particle SEQUENCE INTEGER, DIMENSION(1:3) :: indx END TYPE Particle
TYPE(Particle), DIMENSION(1:nelem) :: particles INTEGER particletype, oldtypes(1:1), blockcounts(1:1), offsets(1:1), extent
CALL MPI_INIT(ierr) CALL MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr) CALL MPI_COMM_SIZE(MPI_COMM_WORLD, numtasks, ierr)
! Setup description of the 3 MPI_INTEGERS fields x, y, z offsets(1) = 0 oldtypes(1) = MPI_INTEGER blockcounts(1) = 3
! Now define structured TYPE and commit it CALL MPI_TYPE_STRUCT(1, blockcounts, offsets, oldtypes, particletype, ierr) CALL MPI_TYPE_COMMIT(particletype, ierr)
CALL MPI_File_open(MPI_COMM_WORLD, "ustream.demo", MPI_MODE_RDONLY, MPI_INFO_NULL, fh, ierr)
disp = 0
CALL MPI_File_set_view(fh, disp, MPI_INTEGER, particletype, "native", MPI_INFO_NULL, ierr)
particles(1:nelem)%indx = -1
CALL MPI_File_read(fh, particles, nelem, particletype, status, ierr)
PRINT*,"derived type" DO i=1,nelem PRINT*,particles(i)%indx ENDDO
CALL MPI_File_close(fh, ierr)
CALL MPI_File_open(MPI_COMM_WORLD, "ustream.demo", MPI_MODE_RDONLY, & MPI_INFO_NULL, fh, ierr)
CALL MPI_FILE_read(fh,iiaux,3,MPI_INTEGER,status,ierr)
PRINT*,"No derived type"
PRINT*,iiaux CALL MPI_FILE_read(fh,iiaux,3,MPI_INTEGER,status,ierr) PRINT*,iiaux
CALL MPI_FINALIZE(ierr) END PROGRAM struct
When I run this program to read the file using just one process, the first two integers of the derived type are not correct, but all the remaining values are correct. All the values when reading them into an integer array is correct. Here is the output:
derived type 24 0 3 4 5 6 No derived type 1 2 3 4 5 6
I don’t get any error from the MPI calls and I used gcc 4.8.1 to compile mpich 3.0.4 on Linux 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux I not exactly sure what is going on.
Thanks, Scot
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rajeev Thakur
