Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
Unfortunately my past experience with hydra is VERY different. I'm baffled as to how you managed to do it so quickly. Surely you have to download the file from mpich.org then unzip (which takes at least 5 mins) then configure (up to an hour) make (a long time as well) and finally make install (another chance in which you can go have a cuppa). And then get the image and put it onto another device which first needs formatting; for me that takes anywhere between 10 minutes and an hour. What did you do so that it took so little time? Eibhlin ________________________________________ From: [email protected] [[email protected]] on behalf of Jeff Hammond [[email protected]] Sent: 16 June 2013 18:19 To: [email protected] Subject: Re: [mpich-discuss] Running an mpi program that needs to access /dev/mem
I did not want to spend a whole day installing hydra instead of smpd if it would not work.
It took me 41 seconds to install Hydra ex nihilo and I didn't even use "make -j". The argument that installation time is a bottleneck is invalid. smpd is not supported and you shouldn't use it. End of discussion. Jeff <snip> ALL DONE Sun Jun 16 12:16:12 CDT 2013 real 0m40.912s user 0m17.405s sys 0m11.028s Jeffs-MacBook-Pro:tmp jhammond$ cat auto #!/bin/bash date wget http://www.mpich.org/static/downloads/3.0.4/hydra-3.0.4.tar.gz && \ tar -xzf hydra-3.0.4.tar.gz && \ cd hydra-3.0.4 && \ mkdir build && \ cd build && \ ../configure CC=gcc --prefix=/tmp/hydra-install && \ make && \ make install && \ make check echo "ALL DONE" date -- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Lee, Eibhlin
